Grinding Wheel for HSS
Results 1 to 18 of 18
    Feb 2005
    Garland ,Texas
    26
    Post
    What wheel i need for HSS on a grinder. white, pink, blue and what grit is best 60,80,120
    Sep 2005
    il.
    6,561
    29
    1181
    Post
    green
    surley some machinest's will step in soon
    Aug 2004
    San Francisco, CA
    985
    27
    8
    Post
    I'm not an expert, but I like the white wheel which is on my grinder. I prefer it to the more common grey abrasive wheels, because it keeps the bit cooler.
    I don't know what grit it is. The coarse or medium grits are better for roughing out the shape of a toolbit from a blank. Fine grits are better for touching up an existing toolbit. A fine grit will work well if you already have a belt sander in your shop for roughing out the toolbit shape. Also, no matter what grit you use on the grinder, you can always hone down the edge afterwards with a slipstone or a diamond E-Z-Lap.
    I believe that the green wheels are made from a different abrasive (silicon carbide) and should not be used on HSS or any steel, because they will crumble away. Green wheels are for grinding carbide and non-ferrous metals.
    Nov 2004
    Mansfield, Oh
    24
    Post
    JohnHC,
    I have a 80 grit white alum. oxid. on one side and a gray 40-60 grit on the other side for roughing in. I belive the green wheels are for carbide.
    JIm Geib
    Mansfield, Oh
    Nov 2001
    WAPELLO, IA USA
    6,425
    29
    1819
    Post
    I like the Radiac BP series. Its a semi ceramic.
    Feb 2004
    latrobe,Pa.
    91
    Post
    Do you have coolant ? What will you be grinding ?
    Feb 2005
    Garland ,Texas
    26
    Post
    Is going on a 6" Balder grider no coolant. Just trying to learn how sharpen HSS tool bit for a small lathe. Thanks for the help..
    Feb 2004
    latrobe,Pa.
    91
    Post
    We use 46 and 60 grit wheels for roughing and 60 or 80 grit for finishing on the hand grinders. Don't use green wheels for steel, they are to soft.
    Mike
  9. Likes Adwcali liked this post
  10. #9
    Aug 2005
    Tacoma Washington
    1,339
    85
    125
    Post
    I have a green wheel that I bought to sharpen carbide tools. It seems to work great for final sharpening of HSS too.
  11. #10
    Oct 2005
    Ont. Canada
    659
    Post
    White : For grinding of most types of steel.
    Pink : For grinding High speed & High chrome
    steel.
    Grey/Purple : For grinding all kinds of tool
    steel, & Vanadium alloys.
    Blue : For grinding HSS over 55RC, Stainless.
    Green : For grinding Carbide & Non metalic
    materials of high hardness.
    Diamond : Are a girls best friend....
  12. #11
    Sep 2005
    il.
    6,561
    29
    1181
    Post
    all correct but me
    Abrasive Types
    Guidelines for Grinding Steel
    3SGP, 5SG— Blue ceramic aluminum oxide. Most durable, for moderate to very heavy stock removal on even tough-to-cut tool steels. 3SG Style is an economical blend. 5SG Style is the highest performance blend.
    32AA and 32A— Gray aluminum oxide for moderate to heavy stock removal of tool steels; 32AA has a slightly higher removal rate, gives a cooler cut, and has up to twice the life of 32A.
    38A— White aluminum oxide. The most friable, for light grinding of all tool steels. Exceptional coolness of cut; ideal for heat-sensitive steel.
    37C and 39C— Black (37C) or green (39C) silicon carbide. For use on non-steel materials, especially carbides.
    Grit— Available in a range from 46 (roughest) to 150 (finest). Choose the coarsest grit that meets your surface finish and form requirements. Here is a starting guideline:
    Grit Approximate Finish Application
    46 Rougher than 32 Ra (roughness average) Roughing; heavy stock removal
    60 Commercial; finer than 32 Ra General purpose
    80 Finer than 20 Ra Fine finish; corner/form holding (.010" radius)
    Grade— An indication of hardness ranging from G (softest) to S (hardest). Start with a grade on the softest end of the range to avoid workpiece damage. Try harder grades to improve wheel life and form holding.
    Grade/Bond Application Contact Area†
    G/VBEP, VSP General purpose Medium-Wide
    I/VBE, VH, VS, VTR General purpose Narrow-Medium
    K/VBE, VH, VS, VTR Corner/formholding Narrow
    † Narrow: Less than 25% of wheel width or less than 1/4" wide
    Medium: 25-50% of wheel width or 1/4" - 1/2" wide
    Wide: Greater than 50% of wheel width or over 1/2" wide
    http://www.mcmaster.com/ctlg/DisplCt...29624578586944
  13. #12
    Feb 2005
    Garland ,Texas
    26
    Post
    The grinder has a grey wheel i can use that for roughing. Get a white 80 grit for finishing. Is there a website that has pictures of how to sharpen lathe cutters. This is for 6061 aluminum stock 1.5 to 1.415 Thanks for the help
  14. #13
    Jan 2004
    Wellsville, KS
    265
    6
    Post
    Here's a website with some info, and plenty of links to more tool grinding info. Should get you started.
    http://www.mini-lathe.com/Mini_lathe...l_grinding.htm
  15. #14
    May 2018
    Michigan
    12
    Blue Norton 6x1 wheel 100 grit is by far best I've used
  16. #15
    Jul 2018
    Connecticut
    Thanks for the info
  17. #16
    Oct 2005
    10,621
    17647
    5588
    Quote Originally Posted by annagreenang View Post
    Thanks for the info
    Building up your post counts there spammer ?
  18. Likes Steven-Canada liked this post
  19. #17
    Jul 2018
    Connecticut
    Thank you for sharing the detail about grinding wheel
  20. #18
    Dec 2014
    Washington
    128
    221
    44
    12 year necro?? This has to be a record!
