home made 5c chuck done! - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 65
  1. #21
    Jul 2004
    Reddington, N.J., U.S.A.
    3,257
    107
    257
    Post
    I don't mean for this question to detract from the finished collet chuck at all. The sheer fact that you were able to design it is a feat unto itself. But I am unable to find the answer in any book I own. Why a collet chuck instead of a collet adapter/drawbar assembly? What advantage does it give you?
  2. #22
    Oct 2003
    East Peoria, IL, USA
    5,407
    349
    806
    Post
    WOW. that's amazing.
  3. #23
    Dec 2003
    North Freedom, WI, USA
    865
    8
    Post
    Jeff, that is very very cool. If I ever made something that nice, I'd be proud and post pictures too. Thanks for sharing it with us.
    John
  4. #24
    Oct 2003
    Idaho
    2,878
    588
    376
    Post
    Very,very nice!
    THe standard of excellence bar is raised!!
  5. #25
    May 2004
    45
    Post
    Unbelievable, very impressive. thanks for sharing.
  6. #26
    Apr 2005
    MA, USA
    2,053
    12
    Post
    That's beautiful. You need to start cranking those out.
  7. #27
    Oct 2003
    ohio
    1,342
    55
    135
    Post
    Thanks again everyone.Showed my wife the responses and she said it must be a guy thing.Kinda like them showing off a sewing project to the girls I guess.
    Peter S ..The large outer handwheel rotates around the body.There is a gear inside the handwheel that turns the small gear that is between the outer and inner gear.The smaller gear then turns the center gear which has been threaded to fit the 5c collets.
    When you push a collet into the chuck and turn the handle it spins the middle gear and it threads onto the collet and then pulls it into the taper seat of the chuck.Simple.
  8. #28
    Apr 2005
    Pittsburgh, PA
    82
    Post
    Very cool! You have an O ring in there as well? Is that to keep stuff from getting to the gears or to keep the handle from loosening?
    Your efforts are impressive. All too rare in this day and age.
    I too get the "I'm glad you like your work dear..." And my wife is an engineering professor!
  9. #29
    Oct 2003
    ohio
    1,342
    55
    135
    Post
    The o-ring was put in there to keep slight pressure on the handwheel so it didnt rattle.There was a tho clearence and I figured that it would make some kind of noise without it.
  10. #30
    Aug 2004
    So. Cal.
    1,490
    5
    Post
    Outstanding work, work of art actually. Its one thing when a company spits out these type of tools with a CNC turning center. Whole nother issue when its been "free handed" conventionally.
    Curious....Was the center gear hardened and you threaded it or did you press in a sleave for threading. JRouche
  11. #31
    May 2005
    Austin, TX
    4,303
    1259
    1189
    Post
    Very clever design! I have the same question as JRouche -- did you make a sleeve that was 5C threaded on the inside, and mated to the planetary gears on the outside, or did you modify the center gear from the automatic transmission?
  12. #32
    Nov 2005
    Maryland
    8,201
    746
    1105
    Post
    Very nicely done, J. Outstanding work [img]smile.gif[/img]
  13. #33
    Oct 2003
    ohio
    1,342
    55
    135
    Post
    Yes the gear was hardened so I bored it and pressed in a sleeve.It was chamfered on the back side and then I brazed it in.Thanks. Jim
  14. #34
    Jan 2003
    Utah
    476
    11
    Post
    J. King,
    Very well thought out and great craftsmanship! I know a lot of people will be copying this. Thanks for posting.
  15. #35
    Jul 2004
    Vicksburg, MS
    4,931
    30
    259
    Post
    Fantastic work. And yes I am going to say it. You should have written this project up and submitted it to one of the magazines. Seeing that this is so much better than everything else they have published in the past two years.
  16. #36
    Nov 2002
    Sweden
    577
    14
    38
    Post
    Two things:
    Gorgeous! As above, as all have said. Really nice. It is too seldom we see an effort towards aesthetically pleasing forms in modern machinery.
    The 3 vs 4 planetary gears thing didn't work because of a fundamental rule of gear math that says the ratio must be evenly divisible by the number of planets.* That's why it worked for three but not four. So your machining is probably just perfect; no mistakes.
    Doc
    *Or something. I'm having trouble phrasing that concisely. AFAIK it makes no matter where on the planetary centers circle the planets are placed.
  17. #37
    Nov 2001
    Mechanicsville, Va
    383
    240
    17
    Post
    Superb! Looks sweet hanging on that 10ee.
    Mike
  18. #38
    Jan 2002
    West Coast, USA
    7,708
    478
    5171
    Post
    Impressive job.
  19. #39
    Dec 2005
    Griffithstown, South Wales, UK
    179
    89
    Post
    Bloody, Bloody SUPERB!!
    Congratulations, now make one for me!
    Croz
  20. #40
    Jul 2004
    Vicksburg, MS
    4,931
    30
    259
    Post
    What transmission donated the parts?
