Horse power vs Man power...
Likes Likes:  0
Results 1 to 17 of 17
    Apr 2001
    Hammond IN
    356
    How do you convert manpower to horsepower ?
    I would like to make a gas powered trailer dolly to move a large heavy trailer. This normally requires 5 or 6 men to move it. This doesn't have to be fast, so I will gear it down quite a bit. It will have to work on pavement or grass, and have enough power to pull up a slight incline (normal parking lot slope). Would a 4 Hp 4 stroke be enough ? Would a 30 or 40 cc 2 cycle be good enough ?
    If anyone else has built or has plans, please feel free to share them. I would like it to have foward and reverse also.
    Thanks !
    Dec 2000
    Bremerton WA USA
    10,693
    41
    4265
    A 180 lb man can push 60 lb for several minutes on good footing. Take it from there.
    Looks like you need 400 lb traction with 800 lb surge. General aviation ramp service people use a factory made powered tiller bar on the nose wheel of airplanes they have to move around. You might use the same thing on the trailer tongue. I suggest you explore using a garden tiller modified with pair of 12" trailer wheels on the output shaft.
    Lots of travel trailer places use a wheeled farm tractor with a three point hitch to move their stock around. I bet a little ATV would work as well.
    Apr 2003
    Berkeley Springs, WV, USA
    4,291
    102
    I worked at an equipment rental yard once. We had one of these little Clark aircraft tugs that was fitted wth a hitch ball that could raise or lower by hydraulic power.
    Jan 2004
    Porter, Tx
    774
    I did a study on "horsepower" on windmills, horses and humans, for a history course...
    a human can produce abotu 1/4 of a hp for VERY limited times, and generally 1/8 for extend (more than 15 mins) time.
    The 2 stroke has no TORQUE at lower rpm which is what you are actually after, btw, as that is your speed control
    a 5:1 or 10:1 gearbox, on a $200 4 stroke would jerk the back back teeth out of a bear. and still have some torque.
    if you really wanted to make your life easy, get a 24v battery, a 1/4hp DC motor, a 10 or 15 to 1 gear box, and make a speed control... plug the batt into a charger once a week and be done with it
    jeffe
    J Tiers Guest
    Power is the time rate of energy delivery. Techie talk meaning that the slower you move the load, the less "power" you need.
    Therefore decide how fast it has to go.
    The weight and lift give you the actual energy, and the time you lift it in (you said an incline) converts to power. The "horsepower" is 33000 foot-lbs per minute.
    Then you have to discount for friction etc. On grass, there will be more friction, so I would derate at least 2:1.
    If for instance it was 33,000 lb, you pulled it up one foot in height of incline, and had to do it in one minute, the theoretical frictionless HP with that formula would be 1 HP, given suitable gearing etc. Actual would be 2 or three HP, due to friction etc. Long trains of gears or belts lose power in a hurry.
    Speed, weight, lift, pick two.
    D. Thomas Guest
    www.powerwheel-usa.com
    (there are others, including a powered "johnson bar" for moving machinery skates and 20,000 + lb machines)
    Apr 2004
    Modesto, CA USA
    7,016
    1180
    I second the idea of a rototiller. many of them have drive wheels with forward and reverse. look at this one on ebay with hydralic drive or look at the barrito website.
    http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
    A gravely two wheel tractor would be ideal but I think they go too high for such a simple use. look at BCS as they tend to go a little cheaper. Consider replacing the gas engine with a battery motor at any rate.
    Bill D.
    The quickest and least modifications needed would of course be to use a horse. Provides variable speed, power steering, collision advoidance sensors, fuzzy logic all right out of the box.
    Jul 2001
    Fullerton, CA USA
    2,898
    14
    The pavement part is easy, the grass is tougher. For traction in the grass, the motive power will need to be heavier with more tire on the ground.
    I have a friend, an engineer of course, who wanted a cheap efficient way to move his T-28 Trojan in and out of the hangar. The plane is a little heavy for the small hand tugs and there was a little slope to deal with. His solution was an electric pallet jack. He bought an old one at auction for cheap.
    He made a fixture to pickup the nose wheel a little and he can move the plane anywhere with ease.
    Les
    Oct 2001
    San Jose, Ca. USA "That light at the end of the tunnel just might be......"
    2,244
    13
    Come and rent my skid steer.. It will easily drag a dead horse.
    Jan 2004
    Porter, Tx
    774
    Metal Doc,
    you sell plans for that?
    wouldn't that be just the ticket, if setup for a mini/low forklift for HSm's?
    jeffe
  11. #11
    Jan 2003
    Jacksonville, Florida, USA
    2,324
    10
    My mover requires just a little bit of compressed air.
    [This message has been edited by sandman2234 (edited 07-21-2004).]
  12. #12
    Jan 2003
    2,324
    10
    Underside shows a little more dirty details.
  13. #13
    Apr 2001
    Hammond IN
    356
    Thanks Guys, lots of great ideas !
    I think D's website won me over to electric mover. Easy to reverse, reasonable light weight, compact size. I will try to copy this style.
    Right now I am thinking a starter motor hooked up to a worm reduction (good reduction, and self braking), then a chain drive to get the final reduction dialed in.
    MetalDoctor, I have moved dead horses, they aren't easy !
    Sandman; What is that thing ? What does it move ? Looks like it uses a LOT of air !
    I will post when this gets under way, I really need this, but my project list has numbers AND letters !
    Thanks All !
  14. #14
    Jan 2003
    Central Kali.
    1,981
    12
    Years ago I saw a small rig with an 8 horse Koler that was used to move mobile homes in a trailer park. I don't remember the details but it was pretty small.
  15. #15
    Jan 2004
    Alabama
    372
    MetalDoc, what is that?
  16. #16
    Dec 2003
    Washington
    4,713
    2226
    4060
    Sandman - that looks like what a lot of paper mills used to move parent rolls around with or carts full of "broke" . . .
    I have an employee who had a rototiller that threw a rod. He fished around in his pile of junk and found a 2HP single phase compressor motor and bolted that up with a tiny pulley on the motor. As long as he keeps the extension cord out of the tines, it is the cat's butt for tilling his garden.
  17. #17
    Oct 2001
    2,244
    13
    KBW,
    That is a Ramrod, small skid steer with 36 hp Kawasaki or Koehler engine (your choice if you buy new) . These things are a tad pricy new, but you can get something like 36-40 different attachemtns for them. I have a 40" dirt bucket and a set of 48" pallet forks for mine. Tough little tractor. Has secondary hydraulic lines for running attachments.
    http://www.ramrodequip.com/
    [This message has been edited by TheMetalDoctor (edited 07-21-2004).]
