Michael Moore
Titanium
- Jun 4, 2004
- San Francisco, CA
I recently bought a used level (I presume it is the Model 199 as the base is completely flat, with no groove for round work as my .005"/foot Starrett has). The bottom of the level looks very nice (actually, the whole thing does, though the box isn't in very good shape) and I can't feel any burrs/bumps along the edges.
When turned end for end the level isn't repeating.
If the bubble is centered in one position, when turned the left end of the bubble is 3 marks to the inside of the right hand center mark. The divisions appear to be about .100" apart, so the bubble has moved approximately 11 divisions.
There's a large screw at one end of the main vial, which I presume is used to raise/lower that end of the vial to bring it into adjustment.
With that screw completely slacked off, I get the above results. But the bubble would indicate that I need to slack the screw off even more.
I can't find any documentation on how to adjust the level at the Starrett site or via Google. Do I need to put a couple thou thick piece of shim stock under the non-adustable end, or is there something else that I'm missing. I've not attempted to loosen all the tiny screws that hold the vial to the cast base.
Michael
Michael
