D
D. Thomas
Guest
Warning- Extremely boring thread to follow-
She who must be obeyed finally demanded I get our doorbell working ! Now, I always thought a knock would be good enough, but nope, gotta have that ding dong. Anyway, after some poking around, I figure out that the upstairs one will work by itself and the downstairs one will "sort of" work by itself, but only dongs without a ding, but together they don't work at all. Seems like they never did work quite right, but use to do something. I get a voltage reading of 10....seems low....~nowhere~ on either unit does it say what voltage they are supposed to be...finally find the transformer hidden away....10 volt label on it. Find the upstairs unit, the one that works, a Nutone model, on the web, sez 10 volts.
So all I can figure is the larger (no name) downstairs unit that only sort of works is actually supposed to be operated at a higher voltage than 10 volts and that even if it was 10 volts a larger output transformer is needed to operate two units. Seems like the solution would be a 16 volt transfomer of larger output...a few extra volts wouldn't hurt the Nutone 10 volt unit, would it ?
