LeBlond Lathe Hydraulic Oil Filter
Likes Likes:  0
Results 1 to 4 of 4
    Mar 2008
    Central Texas
    12
    Default LeBlond Lathe Hydraulic Oil Filter
    I have a 1969 15x54 LeBlond Regal Servo Shift Lathe that has not been run for around 7 to 10 years. I plan on replacing all the lubricating and hydraulic oil, including the Servo Shift oil. I assume the inline filter should be replaced also. Does anyone know of a source for a reasonably priced filter? Knowing the prices that LeBlond Ltd. gets for their stuff, the filter will likely cost me as much as my lathe. I know there are LeBlond owners on the forum. Any suggestions or comments would be welcome. Thanks.
    Wayne
    Nov 2007
    marysville ohio
    9,113
    2590
    6020
    I just get my parts from LeBlond. not cheap but I haven't needed many parts
    Mar 2004
    grass valley, CA, USA
    230
    Tmac;
    If you have the old brass puralator filter, Clean it up and use it.....The new replacement from LeBlond is a small, cheesy unit you have to install outside the housing.....I spent hours with phone calls and email to puralator with negative results.....Here's photos on mine.....(hope this works)
    http://s115.photobucket.com/albums/n...0oil%20filter/ Scroll down to pics.....
    I bought "76" UNAX AW 68 oil for mine, probably same as Shell Rotella 68.....
    Jim
    Oct 2004
    Iowa USA
    131
    That machine is a beautiful piece
    Makes a nice hot rod too in that color
