machining deer bone?
Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Oct 2002
    Kansas City, Mo.
    6,528
    290
    2038
    My niegbor brought over some deer bone and asked for some parts to be milled out of it......I put in on the mill and it cut ok....but the finish wasn't so good and it seems to want to wrap a little from the heat?....so what speed..etc works best? useing a 5/8" HSS end mill, not the sharpest one in my box and running pretty fast....works great for ivory but this is bone...and it really stinks as anyone who has done this knows. Thanks
    Sep 2001
    Midland, Michigan
    668
    Sometimes my take on a post is all wrong!
    My niegbor brought over some deer bone (
    enough for 3 or 4 complete animals
    ) and asked for some parts to be milled (sorted) out of it...... Dead or alive?
    I put in on the mill and it cut ok....Now on a lathe the proper fixture would be the Buck Chuck, of coarse depending on sex. Once you cut the throat, I never put um on a mill to do that but then probably rope it down each side of the saddle.
    but the finish wasn't so good and it seems to want to wrap a little from the heat?....What do you mean the finish wasn't so good - it was a slow death or you can't stand the sight of blood? I like a good freezer paper for wraping and no heat. Or do you mean "wrap" as in wrap music?
    so what speed..etc works best? Work fast enough to finish the job before the LAW shows up.
    useing a 5/8" HSS end mill - What fer, all bamby burgers, no steaks?
    , not the sharpest one in my box Now I've known a few like that i.e., They weren't the sharpest one in the box, you're refering to your neighbor here, right?
    and running pretty fast.... Tell us about the hunt/get-a-way later!
    works great for ivory Oooops! Ivory (gulp) , deer don't have ivory, you musta got yourself an elephant instead.
    but this is bone...and it really stinks as anyone who has done this knows. How long ago was it that your neighbor brought it over, it must a been dead already if it stinketh.
    I'm not sure about the speed but you'll likely experience chatter til he stops kicking.
    Jul 2001
    Fullerton, CA USA
    2,898
    14
    That was good Steve.
    Les
    Sep 2002
    Lawrenceville GA USA
    6,286
    859
    1385
    Most of the people that I know of who wittle bone (Taxidery) use very high rpm machines like fordom die grinders and such. I do not know if they require any additional polishing or not afterward. I will ask around and see If I can find out more.
    Charles
    Jul 2003
    Linwood, Ma USA, the center of the known universe
    274
    I have dabbled in pen and pencil making and have made a few from deer antler but not bone. Antler is easy to work and leaves a good finish.
    I suspect that if you used a new or newly resharpened end mill your finish would improve.
    Paul G
    Dec 2000
    Bremerton WA USA
    10,710
    41
    4375
    Bone, horn, and antler (specialized bone) are very heat sensitive because of the moisture they contain - even "dry" bone etc. In a sense they're like wood having a moisture content reflecting their environment's usual humidity.
    For that reason you chould machine them at relatively slow speeds using light cuts and relatively heavy feed rates. Thus you reduce heat input and distortion from local drying.
    Also bone and antler are abrasive because they're comprised of calcium corbonate and calcium phosphate plates in a horn-like matrix equivalent to a space age composite material. HSS dulls readily in this stuff so when you take a cut, don't dally.
    A water mist might be helpful too.
    [This message has been edited by Forrest Addy (edited 08-05-2003).]
    D. Thomas Guest
    Buck chuck...LMAO
    Feb 2001
    Hotchkiss, CO USA
    1,828
    123
    53
    Everything Forrest said, and!
    Make a few knife handles here, out of bone and various antler. Slow is better, water might help with overheating but I would avoid as it would create problems with trying to finish later, or warpage during drying, or any sealer (like wood, very dry is best)(some treat antler and bone with various plastics to avoid any warpage/shrinking). I use mostly abrasive belts for shaping the material over machining. Even at slow speeds, the belts clog and need frequent cleaning.
    Now you know why your dentist charges so much! When I work the stuff, dogs cruise my yard looking for something good!
    Feb 2003
    Eugene, Oregon, USA
    1,310
    6
    I have made knife handles from bone. Bone needs to be very cured (dry thorugh) to cut and work without frizzing.
    Cutting it at high speeds will butn it and it will stink. Low speeds and it will chip. use medium speeds. For some reason high speed burs work fine in high speed tool for carving. Probably becacuse the contact of the carving tool is not constant.
    It also needs to be very cured to polish. Be very careful of the polishing compounds as the bone is porus and will absorb the color of the compound. I have used wet or dry papers successfully and finished off with rottenstone (White finest pumice) as you would in furniature.
    Jun 2003
    England UK
    88
    BE EXTREMELY CAREFUL! The dust is very dangerous if inhaled......use an extractor
  11. #11
    Dec 2000
    Bremerton WA USA
    10,710
    41
    4375
    Baldrick:
    Bone dust dangerous? Really? Why?
  12. #12
    Jun 2003
    Thomasville, GA
    1,562
    6
    I did a few Google searches and found an article which mentioned a possible link between the inhalation of bone meal dust and Creutzfeldt Jakob Disease, a fatal brain deterioration disease.
    Roger
  13. #13
    Aug 2002
    West Unity, Ohio
    26,355
    6651
    8716
    Just how much experience do you have with ivory?
    Think Snow Eh!
    Ox
  14. #14
    Oct 2002
    Kansas City, Mo.
    6,528
    290
    2038
    Thanks guys for your help with the bone, in the future I'll use carbide and go slower. what I was making was a name plate for the nieghbors sons first deer. Just milled it flat (about .150") and engraved it on the pantogragh (deckel model #GO) and polished it by hand....looked great. OX, I've done a bunch of work in ivory, mostly lathe stuff...threading, fine turning (some parts less than .010 thick)..Ivory is one of the nicest materials to work with, turns and cuts wonderfully....it is almost easy to get a high gloss finish on your cut...try it sometime but use old tusks to save the elephants....I also have interests in ornamental turning.....
  15. #15
    Jun 2003
    England UK
    88
    Bone dust is a carcingen......it will cause lung cancer if inhaled. A friend of mine who turns lace bobbins is accutely aware of this and takes great precautions when machining bone, and also some hard woods are extremely dangerous. I,m not kidding on this one.......
  16. #16
    Dec 2000
    Bremerton WA USA
    10,710
    41
    4375
    Ah! Carcinogen. I wonder why it doesn't give cancer to the living animals who pack the bones around?
    BSE (Bovine spongiform encephalitis) is another matter if the causitive prions are present. Cooking does not denature BSE prions so anyone eating infected meat is in grave danger of infection by a horrible and incurable disease.
    If the prions are absent the animal's flesh is safe to eat. I'd think it follows that the bone or antler from a clean animal is safe to work without special precautions beyond the usual dust protection.
    I dunno. Any experts in cross-species infection around?
    [This message has been edited by Forrest Addy (edited 08-07-2003).]
  17. #17
    Sep 2002
    ohio-USA
    1,340
    87
    26
    Rivett6o8--Any comments for Stuber?? He had me in tears. Either he is an English teacher or a comedian.
  18. #18
    Oct 2002
    Kansas City, Mo.
    6,528
    290
    2038
    Mark...I got a a real kick out of that.....It was good.
  19. #19
    Oct 2002
    Leiden , The Netherlands
    674
    58
    106
    Forrest , the carcinogen part is probably the same as with glass-wool and that other isolating stuff (`Asbest` in dutch) :
    The small particles you breathe in get `woven in` by protecting tissue in your lungs.
    This protecting tissue , in some cases that is, starts growing and growing.
    Eventually some of these cells can start mutating on their own , like any form of cancer starts.
    Not quite sure about that last part , but that`s what I found out today.
  20. #20
    Oct 2002
    CT, USA
    160
    Rivett608: Just an observation on working animal bone. I have found an advantage in boiling(just above simmer)cow bone then leaving it to dry for several days before working it. Just for what it's worth.
    EAH
