Molding question
Results 1 to 19 of 19
    Feb 2005
    AFGHANISTAN
    89
    Post
    Is there any way to melt plastic and squirt it into molds without expensive machinery? I'm talking about production runs of maybe 5-10 pieces. Taking the parts out by hand, no ejector pins or slides involved.
    steve
    Oct 2001
    San Jose, Ca. USA "That light at the end of the tunnel just might be......"
    2,244
    13
    Post
    There used to be a small molding machine that would fit under a drill press spindle and the spindle force would shoot hot plastic into simple molds. I am sure someone in the forum has seen this. I don't have a link. Might try posting in the EDM forum..more mold builders in there.
    TMD
    Jan 2005
    San Francisco, CA
    774
    Post
    Done it myself! It's not that hard.
    There are a bunch of different appraoches to this. Depends on what kind of plastic you are trying to mold etc.
    If you are going to be working with a thermoplastic like a polyethalean (one of my personal favs) then you are going to want to whip up a basic heated cyclander with plunger.
    If you are going to be working with a resin based plastic, then you don't need the heat.
    I've done both these things, with jury rigged home shop style equipment with great success.
    If you could let us know more about what specifcally you are interested in creating I could give more specific suggestions... though I am certainly aware of the desire to avoid specificity in the developement of prototypes etc...
    B
    Feb 2005
    AFGHANISTAN
    89
    Post
    Im not starting a business, so no secrecy here. I was just thinking of making something that clips onto the rails of the bottom of an HK USP40. Something that holds a tiny flashlight or a laser. Not sure of what type of plastic the frame is made out of, but I think it is resin.
    I worked as a moldmakers apprentice for a little over three years(about 5 years ago), but never got the chance to visit any of the shops where they actually made the pieces.
    Jun 2003
    Thomasville, GA
    1,562
    6
    Post
    There's a book about injection molding small plastic parts on eBay:
    http://cgi.ebay.com/BUILD-AN-INJECTI...QQcmdZViewItem
    No connection with seller, blah, blah...
    Roger
    Jan 2005
    San Francisco, CA
    774
    Post
    Well, ok then. You've got pleanty of knowledge about how to make a mold, now all you need is a plastic. For small runs, I suspect that you'll best off using a resin based plastic. There are a lot ot choose from... and you'll need to get the appropriate release as well.
    Here are a couple of companies that you could check out...
    www.smoothon.com
    www.polytek.com
    They both sell various different resin set plastics with various different properties.
    If you are trying to get these things in through a fine sprue, you can mix the stuff up and then suck some up into a disposable syringe and then squirt the stuff into your mold. Even with the faster setting stuff you should be able to get a dozen or so sqirts in.
    Sometimes you'll get some air bubbles this way... if you do and you want to get rid of them, you'll be best off taking the mold after all your squirting is done and putting the whole thing into a pressure pot (grainger) and pressurizing the thing up to 50 psi. This will cause the air bubbles to desolve in the plastic and disapear.
    Good luck.
    B
    Jul 2004
    Boiling Springs, PA
    228
    15
    Post
    It depends on what type of plastic your piece needs.
    There are two-part epoxies, polyesters and urethanes that only need to be mixed and poured. A little vibration or centrifugal force will get the air bubbles out. And parts can be cast from RTV molds. Simple and cheap.
    If it absolutely has to be a thermo-plastic, try that book mentioned above on building your own plastic injection-molding machine. This is a Lindsay Publication and is available at: http://www.lindsaybks.com/
    Wayne
    Oct 2005
    Ont. Canada
    659
    5
    Post
    You can Build one, not to much of a problem.
    First thing though, find out how many oz's
    each shot requires. If you are just doing a
    reload / shot method, then a simple plunger
    will suffice. If not then you are looking at
    a more complex injection group that you will
    have to fabricate. Requiring:
    Barrel, Feed Screw, Torpedoe, Check Ring,
    a Hydraulic Power Supply, Hydraulic Motor,
    Hydraulic Cylinder, 240V Heater Bands, Nozzel,
    Nozzel Heater Band, Required # of Controlers,
    Hydraulic Manifold, Presure & Flow Control Valves
    Presure Gages (aprox 3), Required Hydraulic Hoses
    And the required lengths of 1"x10" steel plate,
    and required hardware, to build the carrage.
    This is called an Injection Group, sounds hard,
    but I made one in about 2 weeks time a few years
    ago. Principals you must understand when injection
    molding, are cycle time, Injection presure,
    Holding Presure, Back Presure, Injection & Feed
    rates,& Clamping Presure, etc.. If you truely
    want to build an Injection Molding Machine, I
    have a few blue Prints of a few comercial machines
    Nissi, Engel, Battenfeld, that I could copy for
    you. Just email me.
    Good Luck in your endevour.
    Jim
    Apr 2002
    Syracuse, NY USA
    9,703
    19
    581
    Post
    low volumn urethane molding in silicone rubber molds is done all the time, you can do anything that can be done in injection molding but the piece price is much higher but low tooling costs. takes lots of skill to make first class parts.
    Jan 2005
    San Francisco, CA
    774
    Post
    One more thing I forgot to mention is that many of the 2 part plastics and rubbers are "Known to the State of California to" do all sorts of not great things to you before they are fully reacted, so do use rubber gloves and keep everything clean and under good control. If you are going to use a product with high VOCs (Polyesters and polyuratheans, among others) be careful with them too make sure you've got good ventilation, and wear a good organic vapor mask with good *fresh* cartriges. Just because you can't smell it, doesn't mean it's not strinking your gonads!!!
    But most of all have fun with this stuff... you can do really amazing things with the various castables.
    B
  11. #11
    Nov 2005
    Connecticut
    60
    Post
    jimmech,
    I'm in the process of gathering parts to build a mini injection group based machine. It'd be great to have a look at some of those blueprints you have. My design exists only in my head, as I've been thinking about it for a couple of years now. I've been lucky to find plenty of items at my company that nobody wanted, such as heater bands, PID temp controllers, metal stock, etc. I'm not sure whether I want to build it using hydraulics or pneumatics yet. I know that pneumatics will give less force for molding and clamping(smaller shot sizes), but it should be a whole lot cleaner and easier, and I can always use a mechanical clamp for the mold. And my air compressor becomes a cheap power unit.
  12. #12
    Sep 2005
    South Carolina USA
    4,478
    2154
    1307
    Post
    There are often some small lab/prototype benchtop injection molding machines for sale on Ebay.. I think one common brand is "Honajector" You can probably buy one of them cheaper than the components to build one, unless you just want to build one...
  13. #13
    Oct 2001
    2,244
    13
    Post
    http://searcht.netscape.com/ns/boomf...bk%2Finject%2F
    This link works, sorry it is so long, just copy and paste or click on it. should work.
    TMD
  14. #14
    Oct 2001
    2,244
    13
    Post
    Here is the machine I was looking for....
    http://www.morganindustriesinc.com/
    TMD
  15. #15
    Jul 2004
    Boiling Springs, PA
    228
    15
    Post
    Okay, you want to hang a light on your HK USP40. Why don’t you try:
    http://www.streetpro.com/usp/surefire.html
    Before these fellows talk you into a $50,000 injection molding machine.
    My gut feeling is that a plastic part is not going to hold up for this application.
    Wayne
  16. #16
    Dec 2011
    Davis, CA
    Default Low cost injection molding machine
    I came across this small plastic injection machine machine recently:
    http://www.techkits.com/pim
    Seems to be aimed for hobby use, prototyping or very small production runs.
    Ed
  17. #17
    Oct 2005
    15,133
    Quote Originally Posted by Metalmasta View Post
    http://www.eatshit and die spammer.com/pim
    Ed
    SPAMMER dredging up old post.
  18. #18
    Mar 2006
    Auburn CA
    430
    39
    Looking at the dates it looks like Digger Doug dredging up an 8 year old spamming post to an even older post of 14 years ago.
  19. Likes dalmatiangirl61, sfriedberg liked this post
  20. #19
    Oct 2010
    Oregon
    5,083
    4325
    1839
    The Net Police gotta police, ya know. No statute of limitations for the crime of spamming. :-)
  21. Likes Bill Simmons liked this post
