my new spindle for a Van Norman #12
Results 1 to 13 of 13
    Sep 2003
    Pacific NW
    762
    8
    100
    Post
    I picked up a Van Norman #12 milling machine about two years ago and have been slooowly refurbishing it. The spindle had the odd ball 5V taper. I received no tooling with the mill so I was considering options for changing the taper to something more common.
    I got a very lucky bit of inspiration when I was at the local flea market and found a guy selling an quick change Erickson R8 (external) to 30 NMTB adapter, the wrench, nine collet holders and about 25 various size collets for $100. He had dragged them to the flea market several times and never had a nibble. What luck!
    I tore down the spindle assembly and discovered the factory spindle was a little chewed up where the seals rode and someone replaced the class 3 tapered bearings with class one. The bearings were rusty any pitted anyhow. In fact I replaced all the bearings in the machine and knew that the spindle bearing would probally need replacing anyhow.
    I researched what material to use for the spindle on this and other boards. I took the original spindle down to the heat treat shop to get their opinion. They hardness tested it and we were both suprised at the results. Basically the hardened skin on the factory spindle was so very thin that the diamond simply broke through and never would give a reading over 25C. Eventually I decided to use 4140 annealed and then harden it to 54C to 56C. $50 so far.
    So I planned on using the 30 NMTB taper and the threaded quick change lock ring feature off the Erickson adapter. This would allow me to have quick change or use the drawbar. I also found 30 NMTB arbors were reasonably priced. The Van Norman is a horizontal and vertical mill.
    I sweated out machining the shaft. I do mean sweated! I am no machinist, just a weekend warrior. It took me about 40 hours. My usual mistake of cutting undersize was avoided by measuring everything with a mike and dial calipers before taking another cut. I turned the bearing diameters 0.030 oversize for finish grinding.
    Off to the heat treat shop. A day and $50 I had it back and was off searching for a guy to grind the internal taper and the bearing seats. I read Forrest's opinions about home grinding or turning a spindle and other than a few seconds of delusion about trying the grinding with a toolpost grinder it never crossed my mind. Honest Forrest
    Finding someone to grind the internal and external in Phoenix was a little difficult. As I mentioned I am not in the machine shop business. Any way 3 months later and $400 I have got it back and it looks great. Couldn't tell you about how accurately it is ground because I don't have mikes that measure to tenths in that size or probally couldn't repeatably and accurately measure it if I did.
    Total cost $500 minus selling off seven of the collet holders for about $75 each.
    Now if I could only figure out how to post a picture
  2. Likes sfriedberg liked this post
  3. #2
    Sep 2003
    Pacific NW
    762
    8
    100
    Post
    Well I figured it out.
    Nov 2003
    Antwerp, Ohio, US of A
    556
    Post
    WOW!!!! What a story, and what a great looking part!!! Wish I had the time/ambition/money to do that on my V/N #6!!!
    Great concept and good job on doing some REAL engineering!
    OMcG
    Feb 2004
    peekskill, NY
    24,541
    4614
    Post
    Wow!! You sir are no weekend warrior now.
    That is one classy piece of work. I need to
    replace the spindle in a lathe, and this story
    has gotten me all stoked up to consider tackling
    it this winter.
    Fantastic job.
    Jim
    Apr 2016
    Louisiana
    64
    57
    20
    Part pics - indeed. No pics are available to me here on this thread? Had my interest though.
    Jun 2013
    england-newcastle upon tyne
    713
    132
    154
    Pictures cant see any?
    Mar 2004
    Princeton, NJ USA
    1,844
    1547
    431
    13 years too late for pics!
  9. #8
    Nov 2017
    Florida
    9
    Do you have a procedure for the spindle removal/instal? I want to convert my vn12 but do not know how to disassemble or set the backlash on the gear for the spundle. Thanks
  10. #9
    Feb 2018
    Missouri
    Photographs cant see any.sir
  11. #10
    Sep 2003
    Pacific NW
    762
    8
    100
    Sorry guys the pics were propably posted via photobucket and we all know what happened there.
  12. #11
    Jan 2006
    Radcliffe Iowa
    640
    26
    77
    I have a ton of 5V tooling, I would just like to find a nice spindle.
  13. #12
    Sep 2003
    Pacific NW
    762
    8
    100
    Quote Originally Posted by chiefaponte View Post
    Backlash is .008 to .013 measured as a typical rear axle gear set would be.
    Pretty easy to disassemble if you have a parts diagram.
    Do you?
    >> ps guys, an original poster has no idea that this topic has been resurrected from the dead UNLESS you PM him.
  14. #13
    Mar 2010
    pacific northwest
    1,049
    6
    220
    Doug,
    I will PM you!
    I am wondering about grinding the spindle on my VN 12 and the thin skin issue could be a serious problem.
    What year is your VN 12?
