Results 1 to 10 of 10
Thread: National Gas Outlet Tap?!
07-22-2006, 02:39 AM #1
Well, its a common thread in the paintball industry, but I cannot find a Tap or die to save my life!
The threads are 0.825"-14 NGO (National Gas Outlet) right-hand male or female. I cant find either.
Id prefer a bottoming tap, the threads are about a half inch deep.
Does anybody know where to find one of these taps?
Also, how would one go about tapping such a hole? Would it need to be automated (cnc) or can it be done by hand?
07-22-2006, 02:59 AM #2
Have you checked McMaster Carr, www.McMaster.com, or MSC, www.mscdirect.com, ?
Grits
07-22-2006, 05:02 AM #3
Neither carry NGO standard taps...sadly.
07-22-2006, 07:25 AM #4
All these standard but oddball gas valve threads are satisfied by taps carried in stock by major tap manufacturers.
You could bore the thread on a lathe in an hour.
08-04-2006, 02:55 AM #5
I know this topic is a little old, but the right thread for an ASA is CGA 320. It will be hard to get a tap. A tap that will work for an ASA would be 1/2 nps. It is slightly off, but will work good, and is more common than CGA 320.
08-04-2006, 04:34 AM #6
I make some parts for air guns we take a paintball co2 tank and make an adapter to fit on bb and pellet guns . The thread on the paintball tank is a 1/2 inch npts( national pipe tap straight)
.825 od and 14 threads per inch.
You can buy it from travlers ,msc mcmaster carr,
its a very common tap.
07-22-2019, 07:40 PM #7
There's no such thing as an NGO tap because there's no such thing as an NGO.
NGO and National Gas Outlet is tossed around a lot and referenced as a spec
that is well maintained like the CGA. Fact is, like Santa, aliens, ghosts &
goblins - the NGO does not exist.
07-22-2019, 08:29 PM #8
digger doug liked this post
07-22-2019, 10:41 PM #9
Better late than never...
11-15-2019, 04:39 PM #10
Dunno where Mister fizz gets his info from, but it is wrong. I have a. 830 X 14 NGO tap that I use for cutting the thread in drop blocks made to accept paintball bottles. The thread specification is detailed in an ASTM document designated F 1750 - 05 and titled Standard Specification for Paintball Marker Threaded-Propellant Source Interface.
Regards
Norris
