National Gas Outlet Tap?!
Results 1 to 10 of 10
    Apr 2006
    44667 Ohio
    283
    Post
    Well, its a common thread in the paintball industry, but I cannot find a Tap or die to save my life!
    The threads are 0.825"-14 NGO (National Gas Outlet) right-hand male or female. I cant find either.
    Id prefer a bottoming tap, the threads are about a half inch deep.
    Does anybody know where to find one of these taps?
    Also, how would one go about tapping such a hole? Would it need to be automated (cnc) or can it be done by hand?
    Dec 2004
    Little Rock, Arkansaw
    1,237
    Post
    Have you checked McMaster Carr, www.McMaster.com, or MSC, www.mscdirect.com, ?
    Grits
    Apr 2006
    44667 Ohio
    283
    Post
    Neither carry NGO standard taps...sadly.
    Dec 2000
    Bremerton WA USA
    10,674
    40
    4232
    Post
    All these standard but oddball gas valve threads are satisfied by taps carried in stock by major tap manufacturers.
    You could bore the thread on a lathe in an hour.
    Aug 2006
    Sonoma County
    5
    Post
    I know this topic is a little old, but the right thread for an ASA is CGA 320. It will be hard to get a tap. A tap that will work for an ASA would be 1/2 nps. It is slightly off, but will work good, and is more common than CGA 320.
    Feb 2006
    South Carolina
    369
    50
    Post
    I make some parts for air guns we take a paintball co2 tank and make an adapter to fit on bb and pellet guns . The thread on the paintball tank is a 1/2 inch npts( national pipe tap straight)
    .825 od and 14 threads per inch.
    You can buy it from travlers ,msc mcmaster carr,
    its a very common tap.
    Jun 2017
    North Carolina
    There's no such thing as an NGO tap because there's no such thing as an NGO.
    NGO and National Gas Outlet is tossed around a lot and referenced as a spec
    that is well maintained like the CGA. Fact is, like Santa, aliens, ghosts &
    goblins - the NGO does not exist.
    Nov 2007
    marysville ohio
    9,363
    2674
    6189
    Quote Originally Posted by MisterFizz View Post
    13 years late to the party you finally set us all straight......
  9. Likes digger doug liked this post
  10. #9
    Jun 2012
    Eastern PA
    947
    240
    423
    Better late than never...
  11. #10
    Nov 2019
    UNITED KINGDOM
    Dunno where Mister fizz gets his info from, but it is wrong. I have a. 830 X 14 NGO tap that I use for cutting the thread in drop blocks made to accept paintball bottles. The thread specification is detailed in an ASTM document designated F 1750 - 05 and titled Standard Specification for Paintball Marker Threaded-Propellant Source Interface.
    Regards
    Norris
