mh454
- Jul 13, 2003
- North Dakota
Hello all. I'm a student in machining and need your help. A friend of mine gave me a project that I'm capable of doing but just need some dimensions for some threads. Basically is a rotating assembly for some large hose (same as your normal garden hose reel but with 2" hose). The fitting that is used is a 2" NPT. The only pipe treads I made in class so far were done with a pipe reamer and pipe tap (3/4"). We had a dimesion on the blueprint that was the opening of the hole for reaming (basically kept reaming till I got that opening dimension). Well this project is a bit different since I will be boring the internal taper and cutting the threads. We need at least 1.5" of threads so I will be cutting a 1.5" long taper (which I belive is 3/4" per foot). Anyone know how I can figure out how big to bore for the threads? Sorry if this is kinda vague but I'm new to this stuff.
