Gearbox
- Aug 6, 2006
- Westfield, New Jersey
After two solid weeks of complete disassembly, derusting, parts repair/replacement, and applying a fresh coat of battle ship grey, my 1969 Clausing barn find is ready to go.
http://www.thelolaregistry.com/DIY/Machine%20Shop/IMG_2381.JPG
Read the manual and everything else I could get my hands on, and outside of now knowing the name of every part of the lathe, I'm still not quite sure on how to make parts. Specifically, what speeds to use for various metals and parts, what cutting tips, how to set up the tooling, compound, lead screw speeds, etc. A really good all incompassing "How To" book written for a leyman like myself would be great if anyone knows of a good recommendation.
So far, as for machining equipment, I have the lathe and a vertical mill that I have been using primarily as a drill press for the past couple of years. But, now with the new toy, I want to make stuff.
I figure for my first project, I'll do something easy (I think) as I need a pivot pin for a window regulator on a 1971 Porsche 911S I'm restoring. The part is about .65" round stepping down to .51" and 1.04" long. It has a slot at one end that almost completely cuts through the larger diameter section to hold the regulator spring, and the sides of the other smaller end is shaved on both sides in order to press fit into the windo regulator arm. The part is turned from 6061 Aluminum alloy which I have a suitable bar. Any ideas from those Master Machinists out there? Thanks Allan
