SteveF
Titanium
- Jul 4, 2004
- central NC
Wiring up my new shop with 240v single phase which will power VFDs, 240v single phase items like my compressor etc. Ran 4 conductor cable but after buying 30 amp and 50 amp outlets discovered that the 4 wire 125v/250v versions don't fit in a standard work box but the 3 wire 250v only outlets fit fine. The only box I could find that would work is a metal square box with a faceplate that centers the outlet and doesn't cover the inevitable gap in the drywall around the box. Yeah, I can fill the gap with compound and screw with it enough to make it look half way decent if I have to. In my old shop I used the 3 wire outlets so didn't realize that 4 wire would be an issue.
So while the aesthetic issue isn't a big deal, it brings up the question - Is there any reason I might need the 4 wire 125v/250v outlets in a hobby shop?
Thanks.
Steve.
Thanks.
Steve.
