Ringing on large dia turnings?
Likes Likes:  0
Results 1 to 15 of 15
    Feb 2007
    Sterling,VA
    257
    53
    Post
    How do you stop the harmonic ring when facing large plates?I have tried slower and faster and even packing rags behind the plate but still get that annoying ring.Help me out what is the trick?Cory
    Jan 2005
    CANADA
    Saskatchewan
    10,238
    1396
    3692
    Post
    Use a small radius insert as is practical, and fairly aggressive feedrate, especially when roughing. It might prove beneficial to switch to ceramic inserts in order to boost the surface speed up into another range that may not get so chattery.
    Inevitably, I think it usually ends up being necessary to drag a spring loaded wear block or perhaps a wheel against the surface. Think about how to be safe before going this route!
    Perhaps some strong permanent magnets could have been secured beneath the plate to give some pull to help provide a contact point to drain some of the vibration into the faceplate.
    Jan 2007
    Newark, DE
    722
    10
    Post
    How big is "large?" How thick is the plate? What is it made of? What tool are you cutting it with, how fast, and with what feed? Depth of cut? What lathe? How are you holding the workpiece?
    I've never had a harmonic ring that wasn't due to a poor fixture, but I've never been involved in what I would consider large facing operations.
    Feb 2006
    New Jersey
    1,420
    7
    49
    Post
    Get some of those large, wide, weighted belts that go around automotive brake drums when they are turned. It makes all the difference in the world on finish too, especially considering many modern rotors are "composite", or have a thin steel hub with a cast iron ring on the outside. Not exactly a rigid setup...
    May 2002
    South Central PA
    13,834
    2404
    3645
    Post
    Try wrapping one or more rubber tarp straps around the OD of the plate.
    Nov 2004
    Birmingham, AL
    13,230
    6617
    2564
    Post
    If you can get wedges of some kind behind the chuck jaws near the center, you'll kill the ring. It'll jack the freq way beyond anything likely to cause problems.
    Think of this like a gong. It's the distance from center to the edge that is causing the problem. Cut it in half and you'll just double the freq, which will just be the next octave harmonic. Catch it somewhere close to the middle, but not in the middle and you'll drive the harmonic way out.
    A hunk of lead bolted to the center will do wonders, too.
    Jan 2003
    Stamford, CT
    1,603
    8
    Post
    I second the straps or use a leather belt. I was also shown to use modeling clay packed into the part depending on what it look like.
    Jul 2006
    SW Georgia
    367
    Post
    I bought one of those things they used to use on brake rotors/drums to stop harmonic ringing.Slip it on the piece to be turned,inflate it and go to work.Works just fine as long as the piece isn't so narrow it won't hold on.I've even used it on non circular pieces but had to be careful it didn't come off.Can only turn at moderate speeds for obvious reasons.
    Sep 2002
    California, USA
    96
    Post
    I've had good luck on large diameter thin wall tubing by packing the side opposite the cut with a layer of DUXSEAL It's kind of like modeling clay. It really helps damp out vibrations. I'd imagine it would work on face turning as well.
    Dec 2006
    Western New York
    20
    Post
    I normally use jack screws between the chuck and the workpiece. Most of our larger chucks have T slots, but if you dont have this option the pressure should keep the screws in place. Just dont stand directly in front of the chuck.
  11. #11
    May 2004
    Nebraska
    413
    14
    Post
    Try a piece of foam rubber thick enough to require a significant amount of compression.
  12. #12
    Oct 2006
    Watertown, Minnesota
    226
    Post
    Yikes!!
  13. #13
    Mar 2005
    Indiana
    4,666
    1208
    1098
    Post
    B Madar uses the same method I do. Our chucks all have T-slots also (there are small drilled and tapped holes at the end of the slots that you can screw a SHCS into to prevent the t-nuts from "escaping"), but where I used to work whenever I needed to use jackscrews on a chuck with no T-slots, I just safety wired them to the chuck jaws, so that way even if they come loose, they can't fly out.
  14. #14
    Apr 2005
    Benton, IL USA
    4,567
    7
    47
    Post
    Another vote for jack screws. As close as the bolt bin or the clamp rack on the Bridgeport. Even on the 24" chuck, they rarely eject, and I've never wired or secured one in.
    Essential on the 48" faceplate on the Niles, big parts squeal like a pig
    Jack screws are just as helpful on the Bpt, when the Kurt jaws are in the outside position and the part is much wider than the vise. Four, sometimes six, make a huge difference in finish quality.
    Barry Milton
  15. #15
    Sep 2006
    Bozeman Montana
    297
    Post
    Bingo!! This is the method I use and it works great. You have to be careful with the jacking screws so you don't put to much pressure and push out the face of your plate if it's kind of thin. Sometimes it's ok to tack weld them to the back of the part just so the jacks can't fly out.
