Texaco waylube D / G & PC - R&O equivs. ?
Likes Likes:  0
Results 1 to 8 of 8
    Mar 2005
    IL.
    113
    Post
    Does anyone know what would be avail from Enco (placing an order today) for:
    Texaco "D" waylube
    Texaco Regal PC-R&O
    Texaco Regal oil "G"
    Texaco Multifak #2 grease
    Texaco Crater No. 2X
    It's for a Clausing lathe.
    If anyone knows what the equivalents are I'd appreciate it.
    [img]smile.gif[/img]
    Jan 2002
    Houston, Texas
    52
    Post
    Have you asked Clausing? http://www.clausing-industrial.com or Jolene Olds: [email protected] .
    Art (Houston)
    Feb 2005
    Madison Wisc
    57
    Post
    I'm looking for the same information. Let's share what we find.
    May 2003
    Iowa
    10,492
    3616
    4269
    Post
    I can help you with some, but like Art said, it's best to call Clausing. This must go back into the 1960's because most is before my cross reference.
    Texaco "D" waylube = Mobil Vactra #2
    Texaco Multifak #2 = Mobilux EP2 or Mobilith EP2
    Texaco Crater #2x = Mobiltac A
    The Regal R&O is rust and oxidation inhibited hydraulic oil. One is for the head stock and the other is for the gear box or apron. My guess would be Mobil DTE 24 or DTE oil-light(ISO-32) for the headstock and Mobil DTE 25 or DTE oil medium (ISO-46) for the other.
    The Mobiltac A will be hard to find. That is an open gear lube with "tacifiers" added. You might have to contact your local Mobil distributor and see if anybody in your area is using it. They might sell or give you some.
    JR
    Mar 2005
    IL.
    113
    Post
    Thanks JRIowa, you're right.
    They (Clausing) really weren't sure on the grease, he just said any grease.
    He said these didn't really "equal" the original , but using these would be fine.
    D = Vactra 2
    PC-R&O is a light hyd. oil = DTE24
    This light hyd. oil goes in the hydraulic variable speed control (and the headstock)...the service guy at Enco recommended DTE "circulating oil" for both at first, until I told him Clausing said it should be DTE24 because it was "hydraulic" system, he then reconsidered.
    G = Mobil gear 630
    The guy at Clausing wasn't sure about the No.2x either, it's recommended for the quadtrant after cleaning, he thought maybe just use the Vactra or way lube on it.
    Thanks !
    [ 06-27-2005, 10:16 PM: Message edited by: Metalworkist ]
    Feb 2005
    Madison Wisc
    57
    Post
    According to a local Texaco distributor Texaco D is a 68 viscosity rating general lubricant. The current version is Texaco's Regal RO 68
    Jul 2004
    Asheville NC USA
    8,867
    3589
    3018
    Post
    Re the Texaco #68....I think you'd be better off using a true way lube like Vactra #2, or whatever the other equivalents may be from other mfgrs. We keep some ISO68 hydraulic oil for certain pcs of heavy equipment, and although way lube carries an ISO VG of 68, it seems a lot more tacky than the 68 hydraulic oil.
    For open gears, I've used both Crown and LubeMaster open gear products which are moly based and come in spray cans. I think Mobil also has a similar open gear lube. Both seem to work very well, and we've used them on swing gears and other open gears on heavy equipment as well as using them on the geartrain on engine lathes. Both are seriously sticky and do not sling off. I've found its best to spray the grease on a slick pc of paper and then apply it to the gears with a small brush, as attempting to spray it and not make a hell of a mess is just about impossible.
    Jan 2019
    District of Columbia
    32
    Quote Originally Posted by JRIowa View Post
    JR
    See picture FYI
    Sent from my SM-G975U using Tapatalk
