M1;
From the OTC manual; Check operation of fuel pump.
Disconnect return line at fuel rail. Connect hose
from fuel rail fitting, to a calibrated container
of at least 1 quart. Connect pressure gage to fuel
diagnostic valve on fuel rail. Disconnect the
electrical connector to fuel pump located just
forward of the pump outlet. Connect auxiliary
wire harness to the connector of the fuel pump.
Energize the fuel pump for 10 seconds, with a
fully charged 12V battery, observe pressure while
energized and allow fuel to drain from hose into
container and observe the volume.
The fuel pump is operating properly if fuel
pressure reaches 35 - 45 psi, & fuel flow is a
minimum of 7.5 oz, and fuel pressure remains at
a minimum of 30 psi immediately after
de-energizing.
Mike;
On the 3.0lt Aerostars, 87-92, many a good tranies
were condemed, due to faulty Watco fuel pumps.
Best replacement were Carter fuel pumps.
Ford cost cutting?
