Axlsavage
Serdi is a single blade system where the cutter is a pre ground form tool which cuts the 3 or more angles in one operation, deflection is controlled by conventional guide pilot below the cutter head & an upper bearing support above it, they work quite well on stem diameters above 6.00mm & will accomodate some valve seat insert pocket machining, they are probably the quickest method of cutting or enlarging a multi angle seat. The downside is the cost, even entry level manual equipment is high & rarely seen on the used market. There are similar units made for use in a milling machine, which may have preceeeded the Serdi, of Swedish manufacture but the name escapes me for the moment.
Neway are multi blade cutters working on an expanding or taper mandrel, to cut 3 angles on 1.5" & 2.00" you would need 6 cutter heads, if the seats were not too shrouded you may get away with 4 cutter heads as the 60 degree & 45 degree may handle both as the blades can be adjusted in the cutter heads. Expanding mandrels are not too expensive though solid taper mandrels can be turned up very cheaply & are much more rigid.
Valve seat grinders dont work for me as all my work is done on alluminium heads with valve stem diameters below 5.00mm, however the orbital recipriocating ones should work very well on cast iron heads of larger throat & stem diameters.
For my own work I use diamond impregnated cones for re-cutting / finishing & Neways for heavier cutting & moderate throat enlargement.
regards
Brian
