Vidmar cabinets- Alternative to drawer pull labels ? - Page 2
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Aug 2005
    Missoula, Montana
    101
    32
    15
    Post
    Hmmm
    1.5" x 22" is an odd size, but most any print shop should have some coated cover scrap that would do the job, just that the order wouldn't be worth running through the office.
    If something smaller would work, I'd go out to my shop and cut you some for $10 for a couple hundred pieces. If you can live with shorter stock (put label over the paper break) let me know.
  2. #22
    Sep 2019
    Lightbulb Diy
    Quote Originally Posted by Milacron View Post
    Called Stanley Vidmar to get prices on the paper and vinyl strips that slide into each drawer pull for labeling the drawers. 98 cents per set....doesn't sound too bad except I have 100 drawers ! Hundred bucks a bit painful for just some strips of paper and clear vinyl, so wondering if I could get a print shop to just shear off 100 1.5" x 22" strips of coated paper (i.e. so I wouldn't need the clear vinyl part) alot cheaper...or ?
    (and the first person to suggest taking a label maker and sticking the label on the drawer front gets a dope slap ! )
    I just bought 2'x4' polycarbonate sheets from Tap Plastics ($16/sheet)and cut them myself....worked great!
  3. #23
    Nov 2013
    Eastern Massachusetts, USA
    4,252
    4500
    4394
    That's an easy job for a print shop.
    Some years ago we needed several hundred blank business cards for an event. The print shop owner grabbed a stack of paper about 100 sheets thick and set his paper shear to the correct width. A few slices later we had our cards, all perfectly sized with neat edges.
    I wouldn't call about this but just go in person. Midweek is usually better as things often slow down a bit and they'll have more time to do tiny jobs like this.
