what is the comparative hardness of metals?
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2004
    Islip, NY
    513
    Post
    Cold rolled steel is only "5" on the Moh's scale. Copper is a lot softer. But what is the hardness ?
    Brass is 3.5 and glass is 5.5, harder than CRS.
    Stainless steel must be a lot softer than CRS, and cutting it may be closer to cutting copper than CRS.
    Just brain storming.
    On the other hand, i was trying to grind through a 5/8 square lathe tool bit, cut it in half on a cut-off saw (grinding disk) and could not get through it.
    On the Moh's scale talcum is 1 and diamond is 10.
    Jan 2006
    WI
    991
    10
    Post
    Alot of metals are judged on 2 different scales all judges by how far either a ball (brinnel Hardness) or a diamond (rockwell hardness) penetrates into its surface. Now each scale has different sizes. Brinnel has different size balls and maybe wieghts. Rockwell uses different wieghts. And of course there is a shore scale for plastics and the like, softer materials. Hope this enlightens you a little.
    Toad
    Jan 2004
    Williams Lake, BC, Canada
    2,892
    10
    Post
    The Mohs scale isn't linear and so isn't a very useful way to compare materials that have slightly different properties. 7075 T-6 aluminum is slightly harder than mild steel but mild steel would be assigned a higher hardness on the Mohs scale as it will scratch the aluminum. The difference between 9 and 10 on the mhos scale is much larger than the difference between 3 and 4 so comparisons aren't easy. It's based on scratch testing and has very limited usefulness in metalwork.
    That's why we use other scales such as the Rockwell, Vickers and Brinell scales.
