Chrisboon
- Dec 29, 2020
- Johannesburg
Hi All
I am not learning fast enough.
Today I discovered that the holes I drill are not as expected.
I drilled 12.5mm holes in 5mm steel. The entrance side measurement is 12.67mm but the other side is 12.53mm.
My first thought was that it was due to runout, one side being closer to the chuck than the other, but then the difference would be the other way round.
Runout on the MT is 0.06mm but on the drill bit shank it is 0.26mm. Maybe time for a new chuck. I did use new high quality drill bits and I did first drill a 5mm pilot hole.
Although it does not matter much in what I do, I would still like to know why this is so.
