Agreed. We used cemented carbide on those DeVlieg cartridges, and when used on the DeVlieg machine, were wonderful, would repeat over the run to a tenth or two. On the other hand, when adjustment was necessary, you did the whole dance.
I had always considered the Tenthset head as a toolroom item, that's how I used it, it's just not stout enough for Otto the hammerman.
Well surely. Look at the guys lucky enough to score a "Tree" boring, surfacing, AND
taper head!
One eyeball at the arm... and you get an "oh SHIT! moment"
Not "am I patient enough to tread carefully".
Surely we can be.
But "can I even put tool to the bugger that is actually any GOOD at
shaving as lightly as that fragile arm has to cut to
not deflect into takes all-day, ruint work, an end-of-life crash, or some combination, thereof!"
I don't even care to "go there" on my "all manual" Old Iron.
Not when NOWADAYS there's a hundred guys that have CNC and can just give it a wish list on code and it generates the cone, cylindricals, and flat faces as if it didn't give damn WHAT sort of preversion you had asked it to create , so long as in the right sequence to allow it, not try to finish-bore a hole as doesn't yet exist!
Bores held to a tenth on Old Iron? Why do I own a "Precise" spindle mounted die ginder? Why do I know about a process - I can send out for, even - called "honing?"
Sadly obsolete Old Fart, I guess?
Guilty on all counts.
BFD. I still eat well enough if I hand-off stuff to better men .. or at least more appropriately equipped!
Try to snatch EVERY crumb off a specialist's plate?
Who TF is it now doing the job YOU were the success at . .back when you still had the
time to do it well?
Need to do tenths? Make the OVERALL investment that assures it.
A good "mothership".
Not just good tooling astride a horse as can't walk a straight line to begin with.
Mind. OP never said.
Funny as Hell he comes back with mega-HP worth of Mazak or the like, and a Cat 50 nostril, when some puffed-up hobbyist is chattering about "Are ATE"!
40 taper here since you asked. Not that it can let me walk on water... That's another one of those jobs for a more expert hand.
