.01 thick 1.25" diameter Carbide Slitting Saw
Results 1 to 10 of 10
    Mar 2020
    Default .01 thick 1.25" diameter Carbide Slitting Saw
    Any body ever run a blade this small?
    Im at 2100 RPM, .0001 FPT
    going in .277" deep.
    had only one nozzle of flood coolant on it no I put all freakin 5 nozzles on it seems to be working.
    I have one where its busted, i dont think I can rerun it. there a tiny bit of carbide and part of little high speed blade i was trying to fish the carbide of old blade out.
    Aug 2004
    Virginia
    2,407
    179
    953
    I have used diamond coated bronze saw blades that thin with good results. I would think it would be asking a lot for a carbide blade due to the brittleness. You did not say what you are trying to cut. Could you elaborate?
    Mar 2020
    oh shoot where did you find those blades at?
    yes the carbide ones suck they are too brittle you can snap one loading on arbor if you dont machine some special spacers for it.
    it 4140, making some equalizing ports.
    Mar 2020
    hmm i dont think that type of blade is what im looking for
    it has to be circular saw
    Aug 2004
    Virginia
    2,407
    179
    953
    This is where I got mine but there are many sources.
    https://www.ukam.com/lapidary_blades.htm
    Aug 2004
    Virginia
    2,407
    179
    953
    Here is another source.
    Barranca Diamond Blades
    I'm not sure what your tolerance is but they have some .014" wide for $40.
    May 2019
    Michigan
    204
    28
    64
    You're running 650 SFM. You might need to slow it down a touch if it's prehardened 4140. Feedrate of .0001 ipt seems really light. You should be able to get close to .0008-.0015.
    Nov 2005
    Illinois
    2,093
    216
    1751
    Solid Carbide Slitting Saw 1.25 X .50 X .01 Thick 32 teeth MariTool
    Should run fine. I would back off rpms A LOT! 150-200 sfpm is a good starting point. Flood coolant, .0004 fpt. .277 is awefully deep for .010 thick. Need to divide up into multiple passes.
  9. Likes mountie, Chris Attebery liked this post
  10. #9
    Mar 2020
    Quote Originally Posted by fmari --MariTool- View Post
    okay ill take notes and fine tune, Hey thanks for the link!
  11. #10
    Dec 2013
    774
    239
    455
    You are going to need to get the runout as close to '0' as possible. You're dealing with tenths per tooth chip load. If you have a few tenths of runout, that will really throw your feed per tooth off.
  12. Likes Chris Attebery liked this post
