1/2-10 5 Start Lead Screw Tap
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    Oct 2019
    ALAND ISLANDS
    16
    Default 1/2-10 5 Start Lead Screw Tap
    Does such a tap exist? I would like to make my own lead screw nuts, but am not overly confident in my ability to cut an internal diameter 5 start thread.
    Alternatively would you go about making a 1/2-10 5 Start tap the same way you would approach making a 1/2-10 single start lead score tap?
    Check out my website!
    The Ballistic Assistant
    Oct 2005
    15,594
    Stick with "off the shelf"
    Jul 2004
    Houston, TX USA
    30,045
    Likely need a version of one of these RELIEVING ATTACHMENTS. Taps with multi start threads need all the help they can get - as in being able to power them thru
    YouTube
  4. Likes LexD liked this post
    Jan 2007
    Norfolk, UK
    18,935
    14440
    14504
    I know my maths isn't good (aka please check) …..but I make the helix angle of that 5 start thread 18.57 deg ……..
  6. Likes JST liked this post
  7. #5
    Oct 2019
    ALAND ISLANDS
    16
    My brother gets access to his university machine shop and has lots of fancier tools then I do. I floated the idea of him making a tap, or just have him make the nuts on the CNC lathe.
    I suspect that is probably the solution. Being the ďDo it yourselfĒ curmudgeon that am, I wanted to explore that option first.
    Since I am not able to find a tap, I figured it was either such a rare thread that a tap is a custom job, or there was a practical reason such as high cutting forces that makes using a conventional tap impractical. I just wasnít finding a good reason ďWhy notĒ online.
  8. #6
    Virginia
    27,666
    7561
    8612
    "Why not" is you are likely to ruin four before you get ONE "good one".
    And all you will have learnt is that no one else NEEDS the same oddball in a several year period as should last you the rest of a natural life. Even if you are still young.
    Stuff like that, as with headlamps or tires for a motorcar, you "just buy".
    If/as/when not "stock" then made by some other Pilgrim who does these things for his own "Day job" and can get it right, first go, ''coz for HIM it is just one more in a long line of similar goods he's already tooled-up for and experienced at doing.
  9. #7
    Oct 2019
    ALAND ISLANDS
    16
    I get that, a lot of what I do, I know Iím not going to get it right the first time around. I figure itís an opportunity to learn something a little knew. Iím used to building a jig or two for a one off job that I could pay someone to do, or purchase the part myself. Itís about the experience and learning for me.
    Thanks for the input guys
  10. #8
    Jun 2008
    Roanoke, VA
    671
    192
    253
    I think your choices are to single point it, or my preference if loading allows, cast one from Moglice.
    Ive made 3/8 acme lead screw nuts from Delrin by using a ball end mill to make 3 grooves slightly off center such that the cutting face was slightly hooked and then cut a taper on the od. I didn’t back relieve it. Worked fine at a 1.5/1 L/D.
  11. #9
    Virginia
    27,666
    7561
    8612
    Quote Originally Posted by JayAndrew View Post
    I get that, a lot of what I do, I know I’m not going to get it right the first time around. I figure it’s an opportunity to learn something a little knew. I’m used to building a jig or two for a one off job that I could pay someone to do, or purchase the part myself. It’s about the experience and learning for me.
    Well - it isn't IMPOSSIBLE.. it just takes good general skills and a measure of dedication.
    Member TRBoatworks is a consumate CRAFTSMAN, new only to metalworking lathes. Already HAS a fine hand and eye, great problem-solving skills.
    He made a nut - two-start, IIRC, on his lathe, FOR his lathe, and did it rather well, first go, and from a cold start.
    OTOH, his lathe is a Hendey Tool & Gage. One of the simplest systems ever built to do good threads with minimal effort or risk of screwups.
    I own an even better one. The inherently inch/metric Cazeneuve HBX series with the "special apron" "B suffix.
    Awesome manual threading repertoire.
    OTOH, "simple" comes only after standing a dual major in shop practices and advanced mathematics, so to speak. It does not start out "intuitive" at all. One has to learn its curious ways. Only THEN does it come good.
    Or so I f****g HOPE it does!
    This.. is how yah know you are gittin' old.
    Go take a short break for an ignorant s**t, yah have to be re-trained on return...
  12. #10
    Oct 2019
    ALAND ISLANDS
    16
    The project is for a 3D printer, in total I need four nuts. I have four lead screws driving two axisís. Loading isnít going to be high. Iím using the high lead screws to get the speed up.
    Iíve done some single point threading on the lathe, an I am by no means an expert. The more I do reading on threading for lead screwed with multiple starts, the more I suspect that I will not have the gearing on the lathe to turn it myself. Iím working on an old engine lathe.
    It may be something I see what my brother can do and see if he is able to make them and possibly abandon the idea of a tap. I will be a good project for him, heís going to school for this type of stuff and he enjoys odd ball projects on the CNC lathe.
  13. #11
    Virginia
    27,666
    7561
    8612
    The project is for a 3D printer, in total I need four nuts. I have four lead screws driving two axis’s. Loading isn’t going to be high. I’m using the high lead screws to get the speed up.
    I’ve done some single point threading on the lathe, an I am by no means an expert. The more I do reading on threading for lead screwed with multiple starts, the more I suspect that I will not have the gearing on the lathe to turn it myself. I’m working on an old engine lathe.
    It may be something I see what my brother can do and see if he is able to make them and possibly abandon the idea of a tap. I will be a good project for him, he’s going to school for this type of stuff and he enjoys odd ball projects on the CNC lathe.
    You will get the power requirement loading up a lot sooner than the speed!
    Having had hands-on in modifying 8-inch floppy drives and the odd pen-plotter or paper-positioner / document feeder about two hundred technology years ago? Some of that on seriously "deep pockets" cold-war Government scanner contracts?
    You really, really, SHOULD be using recirculating ball screws and "stock parts" ELSE anchored synchronous (toothed) belts, metal bands, taut stranded cable, even linear servo motors or "voice coil" positioning for that application, AND NOT higher-friction, higher WEAR sliding action screws and nuts in chronic need of adjustment to try to hold accuracy over time where there is a LOT of movement, even in a SHORT time.
    This is not new ground by easily fifty years, already - disk drives and printers, 3-D or otherwise. CNC critters to office automation, all types, dot matrix Okidata 82 A (toothed belt) to CNC machine-tools the size of a house.
    Ballscrews or toothed belts are not a luxury for durable, low cost, low maintenance 'puterized positioning, least of all when it gets as fast and furious and unpredictable as anything "rasterized" will need to be even if it is given a few thousands of years head-start on 3-D printing of 'bergs for the next ice-age.
    They are a necessity, present economics.
    "Futures" OTOH?
    Already "out there'.
    Must have been 1969 or 1970, IEEE "Eascon" show, Sheraton, DC.
    IBM had a quad booth right next to my firm's double booth. THEY had an 80,000 line per minute printer on display. Awesome critter raster-printed 2D characters so fast, all one saw was a tall stack of "superfold" paper vanish from the input stack and show up on the output stack.
    "Printer" didn't MOVE the head.
    AIMED a jet-stream of sticky carbon particles at that dead-tree paper if it were an open air CRT tube lighting-up phosphors, other end of a glass CRT tube with a beam of electrons.
    But it was boring.
    Our little nuthin'-much firm had borrowed-back a project we had done for NASA, Greenbelt's OSO G orbital solar observatory satellite. UV spectrophotometer monitored sunspot activity.
    The "world's first" computerized colour digital display. On a Ball Brothers Research Vacuum-tube lab-grade industrial CRT display and heavily modified, even so.
    All of 64 pixels by 64 pixels, and "bleeding edge" for its day, if you can relate THAT to what we take for granted NOW?
    And yet? It was INTERESTING to watch where the "world's fastest printer" was BORING.
    So we clocked more visitors than IBM... even though our piddly little annual turnover would not have bought their well-paid staff's LUNCH for even a single day.
    Look at the colour digital display on even a cheap handheld.
    Keep on innovating.
    There's always hope....
  14. Likes steve-l liked this post
  15. #12
    Oct 2005
    15,594
    TheHarryHomeshopidiot
    Again..."Buy them"..
    And NO I don't want to visit your website, please stop posting that at the end of every post.
  16. #13
    May 2010
    DENMARK
    3,446
    4032
    12622
    Those that have a website can put it in their profile NOT IN A POST.
    An exception might be if what's in your website is relevant to the thread.
  17. Likes rustytool liked this post
  18. #14
    Oct 2019
    ALAND ISLANDS
    16
    Quote Originally Posted by Gordon B. Clarke View Post
    It is part of my signature line. Itís not something I am typing in every time. I am still learning to use the tapatalk app, and I didnít realize that It could turn that off on a reply, or that unlike the on the computer it would should up as part of the post rather down below the signature line.
    I think that I have fixed that here. Sorry, still learning.
    Anyway...
    Posts saying ďGo buy the partĒ arenít helpful. Yes McMaster sells them for $65 a piece, and i can buy them. I bought the lead screw stock from McMaster. Having more time then money, and having a desire to learn, I want to try and figure out a solution, as if I couldnít just go buy the part.
    If itís something that is best done on a CNC lathe, which I am thinking it is, I have a brother who would love to tackle something like this. So it helps him try something new and learn.
    The reason I am going with lead screws instead of a belt drive is that the printer has a heavier print head then most and I would like to swap out the print head for a engraver. Based on what I have seen in the market the lead screws were a better option then cogged belts.
    Ball screws are an option but for me it came down to the budget.
    Movement speed for the X and Y axis are 50mm/s which is fast, to me, but is on the slow end for printer. The 1/2-10 5 Start is .500 per revolution, which gives me (in theory) a resolution of .0025 per degree. Which is far better then the resolution that we can expect from extruding out plastics. It is a good balance between speed and precision based on the stepper motors I am using.
    Definitely not trying to reinvent the wheel here. 3D printer are built on decades old tech with some modern computing thrown in. A lot of the component selection and the design is based on a lot of seeing what has been done with other builds.
  19. #15
    Norfolk England
    2,285
    2631
    1695
    It is part of my signature line. It’s not something I am typing in every time. I am still learning to use the tapatalk app, and I didn’t realize that It could turn that off on a reply, or that unlike the on the computer it would should up as part of the post rather down below the signature line.
    I think that I have fixed that here. Sorry, still learning. .
    Digger Doug was correct about your website but don't lose any sleep over it, people who have been here a lot longer than you do it regularly.
  20. #16
    Aug 2005
    Tucson AZ
    6,372
    9610
    3002
    I thought signatures were not allowed here. They shouldn't be.
  21. #17
    Norfolk England
    2,285
    2631
    1695
    Quote Originally Posted by tdmidget View Post
    Depends who you are I suppose.
  22. #18
    Sep 2010
    Oklahoma City, OK
    4,472
    773
    1848
    Make a tap, it's pretty easy. Last one I made was for a delrin nut to I used some stressproof. Was it perfect? No, the geometry left some to be desired but it cut a nice enough thread to achieve my goals.
  23. #19
    Oct 2019
    ALAND ISLANDS
    16
    Quote Originally Posted by Cole2534 View Post
    Does the number of starts or high lead angle complicate cutting the thread with a tap? IíE are the cutting forces so high with a tap that youíre more likely to break the tap then to cut?
    I think thatís what some others were eluding to here.
  24. #20
    Sep 2010
    Oklahoma City, OK
    4,472
    773
    1848
    Maybe. Lotta variables, but the biggest one is- what's your nut material? Maybe I missed it. Next Q- will your lathe cut 2 tpi?
    Cool thing about making your own tap is that it can have a really long taper to ease those forces. As for 5 starts, most lathes won't accommodate that without some help, the thread dial isn't divisible by 5. Swing the compound's travel axis parallel to the spindle axis and that's how you work your starts.
