dalmatiangirl61
- Jan 31, 2011
- BFE Nevada/San Marcos Tx
I'm trying to figure out what tap I need to tap a hole that a 1/2" EMT Conduit fitting will thread into, this is a standard electrical fitting with the thin nut, normally used on sheet metal, I need it to screw into 1/4" thick steel. A 3/4-16 is too small, a 7/8-14 is too large. After 2 hours of searching shop I cannot locate a standard thread pitch gauge, just 3 metric sets and none match the fitting. Looks like 4.5 threads per 1/4", so maybe its 16tpi? Major diameter of the threads on the fitting is .800 , is this a proprietary thread? Maybe I should be using a different fitting?
