1" ER32 Collet??
Results 1 to 14 of 14
    Jul 2007
    USA - Ohio
    259
    5
    Default 1" ER32 Collet??
    I would love to have an ER32 collet with a 1" opening. Does anyone know if such a thing exists. I have not found one using the web so far so most likely it does not. I did see on a previous post that someone had said the "2" "ER32" indicates the largest possible value is 20 mm ...
    Apr 2004
    Monument CO USA
    2,080
    10
    121
    I thought 32 was just the OD. Otherwise an ER25 would take a 50mm.
    Chris P
    Nov 2001
    WAPELLO, IA USA
    6,407
    29
    1833
    you have to go to er40 to get 1 inch capacity
  4. Likes Matt_Maguire liked this post
    Jun 2007
    New Zealand
    2,673
    28
    I seem to recall RegoFix or one of the other Euro suppliers do make an oversize or two for ER32, but I think it maxes out at 22mm. You would need to handle these with care: they will be easy to snap
    There's just no way of pushing the envelope to make a 25mm ER32 - unless you find an extra dimension after z and before t
    Nov 2005
    Illinois
    1,978
    209
    1419
    It is possible. Wall gets pretty thin and the collet itself gets pretty short. I have a couple and have toyed with the idea of selling them. I decided it presents too much liability.
    Jul 2007
    USA - Ohio
    259
    5
    It would be used for work holding rather than cutting tools and fairly low speed < 1200 rpm so I don't see as too much risk using this way. If you change your mind, drop me a PM ... Sure would help me out!
    Quote Originally Posted by fmari --MariTool- View Post
    Oct 2005
    NORWAY
    877
    358
    187
    I have metric ER32 collets up to 26mm. They work just fine, no problems.
    I have never seen them so large in inches though. I would like to have a 1" too.
  9. #8
    Jan 2019
    UNITED KINGDOM
    Post Large ER32 Collets
    Quote Originally Posted by Panza View Post
    If anyone is still looking for ER32 Collets larger than 20mm, including 1", then the ebay site for Gloster Tooling were advertising them recently.
    eBay - Page Not Found
  10. #9
    Apr 2011
    AUSTRALIA
    105
    31
    37
  11. #10
    Aug 2019
    New Jersey
    Quote Originally Posted by rkward View Post
    Hi I just saw these on ebay I don't know if they would work for you they are mm.
    Here is the link
    Oversized ER32 Collet - 21mm (53/64), 22mm (7/8), 23mm (57/64) or 24mm (15/16) | eBay
    and the second link
    Oversized ER32 Collet - 25mm (31/32") or 26mm (1-1/32") USA/Canada | eBay
  12. #11
    Sep 2010
    Oklahoma City, OK
    4,182
    721
    1765
    You're a dollar short and a decade late.
  13. #12
    Dec 2008
    Portsmouth, England
    873
    288
    543
    Quote Originally Posted by Cole2534 View Post
    Though I generally get huffy when I discover I'm reading an archaeological thread, I missed this one last time round and there is information in it which I find valuable. I vote we let him off with a caution.
    George
  14. #13
    Nov 2003
    Beaumont, TX, USA
    4,918
    171
    1495
    The 32 or any of the other size numbers for ER collets refer to the OD, in mm, at the largest/front end of the rear taper. The front taper, which fits in the nut, will be just a bit larger than this: I don't have an explanation for that, but it is.
    The size of the largest hole that a given series of ER collets can have is determined by that OD and by the geometry of the two tapers. It has nothing to do with the second digit of the nominal size.
    I did see on a previous post that someone had said the "2" "ER32" indicates the largest possible value is 20 mm ...rkward
  15. #14
    Nov 2005
    Illinois
    1,978
    209
    1419
    When looking at the tool holder. The theoretical sharp corner where the tapered bore meets the front face with be 32mm exactly. On the ER32 the other end of the taper bore should not be larger than .95" Id. If any larger coolant sealing collets may leak. So 1" ER32 collets will not pass thru the tapered bopre area, thus you can't swallow much depth.
