10 degree modified square thread
Results 1 to 20 of 20
    Jun 2011
    10
    13
    Exclamation 10 degree modified square thread
    Hello!
    I have to make a part which calls out for a 3.5"-11 10 degree modified square thread (interal). I have no information about this type of thread other than what is in the 28th edition of the Machinery's Handbook page 1849. What I've figured out so far from the little information in the book and that the thread is 11 threads per inch (.0909 pitch) is that the root would measure .0494, the crest would measure .0415 and the height would measure .0454. I still don't know the major diameter of the internal thread. I'm not certain if my calculations are correct either. Can anybody offer any more information on this? Any would be greatly appreciated!
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,079
    4134
    3911
    I cut modified square threads for a proprietary device. That said, it is not necessary to fit anyone's parts but my own.
    I believe you have to add .010 to the tooth depth for clearance.
    This makes the crest (as you state) .0415
    Depth is .04545 + .010 = .055
    root = (tan 5° x .055 x 2) + .0415 =.0096 +.0415 = .0511
    Tip of threading tool width is going to be pitch - root =.090909 - .0511 = .03991" = .040" practically.
    By what i have used, the ID/bore of the "nut" would be the OD male thread - 2 x .0454545 = OD - .091" since the clearance (.010) is already spec'd on the male thread. From what I have understood, the radial clearance is on both parts, IOW same tool used for ID/OD. Compared to acme threads, this would yield a flank bearing thread. Possibly like acme there may be a centralizing form used in some apps. I do not know. If this is to a print, the customer should specify.
    Subject to correction by more experienced observers and worth every penny paid.
    smt
  3. Likes antmob, Joe Rogers, awake liked this post
    Jun 2011
    10
    13
    Thank you so much for you input Stephen. It is very much appreciated. I will use .01" as clearance as you mentioned. I did not get any information regarding the screws dimensions so I'm just going to have to hope that the part I make will fit. By the way, the call out for the thread on this part states that it is a 3.5"-11 internal thread. Does this mean that the minor diameter on my part should be 3.5"?
    Jul 2013
    Indiana
    3,272
    4801
    1651
    No you'll have to back figure to get the minor. 3 1/2 will be the major. Thread hight plus the clearance X2 subtracted from the major should give you the minor dia.
    Brent
  6. Likes antmob, James H Clark liked this post
  7. #5
    Jul 2013
    Indiana
    3,272
    4801
    1651
    You have something to check it with? If not I'd consider making a plug first.
    Brent
  8. #6
    Jun 2011
    10
    13
    Thank you. Yes that makes sense.
  9. #7
    Jun 2011
    10
    13
    No, I have nothing to check it with.
  10. #8
    Sep 2010
    Oklahoma City, OK
    4,825
    853
    1997
    CAD and thread wires should get you a reasonable check.
  11. Likes yardbird, antmob liked this post
  12. #9
    Jul 2013
    Indiana
    3,272
    4801
    1651
    Quote Originally Posted by Cole2534 View Post
    That is a good idea! How do you use wires on an ID?
    Brent
  13. Likes TeachMePlease, camscan liked this post
  14. #10
    Sep 2010
    Oklahoma City, OK
    4,825
    853
    1997
    Quote Originally Posted by yardbird View Post
    Brent
    You don't, you make a plug. I supposed one could use gage balls and some patience with an adjustable parallel or stack of jo blocks.
    Side note- anyone know how to hand calc that? IE- how deep would a ball of certain size fall into a cone of a certain angle (your thread flank angle).
    Hell, apparently I already learned and forgot this.
    Measuring Taper with Gage Balls
    All you need are 3 appropriately sized pins, 2 of which need to be matched, and a micrometer.
    Taper Measurement Using Gage Balls | Math Encounters Blog
  15. Likes antmob liked this post
  16. #11
    Nov 2003
    5,342
    187
    1731
    Thread wires on a 10 degree thread? A caliper or worse yet, a micrometer which has the mechanical advantage of a screw thread, will just jam those wires down the Vee. Unless you have an awfully delicate touch, any reading you get will be +/- 0.010" or more. And any roughness on the surface of the thread will be multiplied by a factor of 5 or more.
    Good luck with that. I would grind the thread cutting tool to the width spec and plunge it into the stock the required distance. Measure the major and minor diameters and when they are right, call it done. Be sure to include that extra clearance you subtract from the minor diameter.
  17. Likes antmob, 4GSR liked this post
  18. #12
    Jun 2011
    10
    13
    Hi everyone. Id like to thank everybody for their help and input on my question. Here are some pictures of the finished part.
    20170213_131836.jpg20170213_131920.jpg20170213_131953.jpg20170213_132012.jpg20170213_131718.jpg the finished part and the cutter we ground.
  19. #13
    Jul 2018
    Florida
    24
    7
    Hi All,
    I have a similar problem. I have never seen a thread like this (original shown.) The top angle measures 10 degrees. The male thread is slotted and the female thread is tapered to tighten down on a threaded shaft. The 10 deg-14 male thread is .625". The female thread has a taper and has a .002" tolerance to grab the 1/2-28 threaded shaft and bottom out the nut. I don't have a picture of the nut but will try to get one.
    WAZP
  20. #14
    Jul 2013
    Indiana
    3,272
    4801
    1651
    Yeah me neither, I'm not even sure I see exactly how this works let alone know what What is it? Stupid question but you see nothing in the MH?
    A female nut screws on making it collapse on a shaft? Kinda looks like a hose barb a little. I can't tell by the picture but the original looks to be machined and not cast? Knowing what it is might help folks help you figure out the thread.
    Brent
  21. #15
    Jul 2013
    Indiana
    3,272
    4801
    1651
    What you have is different from what the OP posted about in this thread. It looks like the 10deg on your thread is 10deg off parallel to center line. His is 10deg perpendicular to the center line...J/S
    Brent
  22. #16
    Jul 2011
    Americus, Georgia
    428
    544
    134
    I have seen similar features on devices that require field assembly and disassembly with near absolute holding power with some amount of adjustment to position. Looks like you are doing good so far.
    today is 02022020 radar date
  23. #17
    Feb 2007
    St. George, Utah
    1,031
    562
    686
    . . .Kinda looks like a hose barb a little. . .
    'Cept the 'barbs' are backwards! I think tolerances would be pretty tight on that one since the apparent pulling force would be against the shallow slope of the thread flank.
  24. #18
    Oct 2005
    17,214
    Quote Originally Posted by muckalee View Post
    "clockable"
    1/2-28 is an important detail for sure.
  25. #19
    May 2011
    southern in.
    1,503
    2003
    406
    Quote Originally Posted by WAZP View Post
    Hi All,
    WAZP
    It's a buttress thread. The MH book has plenty about buttress threads, at least mine did forty years ago. We made a lot of parts that were made of carbon (molten metal pumps). Many of them look similar to the parts by Antmob in post #12. Our engineers were doing a lot of experimenting with push type threads and pull type threads, some with 7 degree faces.
    JH
  26. #20
    Aug 2006
    montana
    400
    228
    166
    WAZP I wonder if your part is designed to grab and hold a part when a sleeve is threaded on it, if the sleeve was made with a slight taper.
