machine1medic
Titanium
- Jul 1, 2006
- Clover Hill district, WI
Many many moons ago one of the Old Masters that I was overcome with
had made a large set of "Chain-V's". All I really ever retained was when
I asked him why the 120 degrees looked a little tight, he said
"It aint 120", and said what it was, and why.
My whole intrigue at the time was the size of the Bar (HBM) and I barely
payed attention to his answer. This week in my exploration forced by
the necessity of doing 4 Large bearings (Bores are 22" nominal),
without haveing any V-Blocks anywhere near large ehough, I used a
lever-hoist and my Devlieg modulars to git-R-done.
Man IT all came back to me, out of the foggy past!
108 Degree Chain - V'Block (re-discovered)
His premice was / is a Pentagonal "squeeze" by the chain.
He even showed me that if a tube-wall was thin and tended to distort
you could adjust by inserting a block to pull the top "in".
I assume this is what he meant, his part didn't need it
and mine don't either..... as wall thickness is addequit.
{ schetch is conceptual only }.......... BUT I'm onto a few Ideas.
Open to the "Best Idea" (challenge) as I rarely find mine till I'm done.
Gimmy some metal BOSS !!
Oh Oh OHHh,,,, He said a 90 doesn't give the right squeeze or a good size-range,
and more blocks would need to be made. And he didn't like 120's as
too much downward distortion was the tendency causing oval bores.
