12 volt hydraulic pump needed. High volume with 120psi max.
Results 1 to 5 of 5
    Dec 2012
    Se Ma USA
    1,643
    126
    906
    Default 12 volt hydraulic pump needed. High volume with 120psi max.
    I have a European panel stacker with a 1000kg capacity. As delivered it looks like a small pallet stacker and lifting is air over oil. As you slide panels off the forks lift to keep the top panel at the set height, or slide them on and it will lower by that amount.
    I want to convert it to electric use because I never use it for panel stacking. It has a 6" ID lifting cylinder and a big enough oil tank, just need a pump and battery. Any ideas?
    Mar 2008
    vacaville ca
    465
    62
    127
    check northern tools. in the trailer section for dump trailers and it's been a while but I think they also have a hydraulic section in the catalog that may have something.
    Jan 2010
    Indianapolis, Indiana, USA
    5,473
    2426
    934
    Not sure about your math...
    2,200 divided by (3*3*3.14159) equals 78 PSI, approximately.
    I suggest a 12 volt AIR compressor, most likely cheaper, and easier to adapt.
    http://www.ebay.com/itm/NEW-FOXX-AIR...90484c&vxp=mtr
  4. Likes Bobw liked this post
    Feb 2005
    9,130
    14461
    10915
    Air over oil... At first I was looking at cylinder size and thinking that is huge for a hydraulic cylinder.
    You can get moderately priced 12v pumps, but with the volume they move, it would take forever to lift whatever you want to lift.
    At the pressure needed you could run it on a garden hose with a few valves.
    You are looking at a gallon and half per foot of lift.
    But its already set for air over oil. 12v air compressors are cheap, far cheaper than even the cheapest hydraulic pumps.
    Jan 2010
    5,473
    2426
    934
    Quote Originally Posted by Bobw View Post
    Great minds think alike
