bisctboy
- Oct 22, 2020
Hi - I am drilling 3/32" cross holes for a safety pin in 1/4-20 stainless steel threaded rods. I am also doing the same thing in 1/4-20 stainless hex head bolts. I am using a pneumatic Heinrich cross hole drill jig to hold the hardware on my drill press while I drill through them. Both the threaded rod and hex head bolts are 18-8 stainless steel. Drilling through the hex head bolt is relatively easy and I go through a 3/32" cobalt bit about every 35-50 bolts. However, I go through cobalt bits much quicker on the threaded rod. Sometimes I only get through drilling 5 rods before the bit breaks or just won't drill anymore. I'm averaging somewhere around 20-25 drillings before the bit breaks or just won't drill anymore. I am putting a drop or 2 of cutting oil every time a drill. Again, both the hex bolt and threaded rod are listed as 18-8 stainless. Does anyone have insight as why I go through many more drill bits on the threaded rod? Are there different types of 18-8 used on bolts versus threaded rod? I will add that I buy the bolts and threaded rods from 2 different suppliers and the hex head bolts have a bit more of a "shine" to them than the threaded rods.
Thanks!
Thanks!
