1st grade math question
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Dec 2015
    45
    9
    16
    Default 1st grade math question
    What is the gear ratio?
    Driver gear is 34 teeth the driven gear is 32 teeth. So is it 1.0625:1 or .941:1
    Feb 2007
    St. George, Utah
    1,047
    594
    693
    I learned it as the revolutions of the driving gear / driven gear. So to me it is .941:1
    The example that comes to mind is the rear-end ratio on a motor vehicle, 4.11:1 etc.
  3. Likes Scottl, blueboy, BoxcarPete, Bobw, jz79 and 2 others liked this post
    Sep 2006
    Stillwater, Oklahoma
    1,481
    110
    813
    I have trouble remembering which way things go too, so usually resort to some sort of logical cross check to clarify. In this case, I see that a larger gear is driving a smaller on, meaning that it will be speeding up the output. So having two possible numbers to choose from, I'd take the larger one, 1.0625.
    Nov 2018
    Michigan
    417
    197
    240
    I'm going to side with Gordon on this one. Don't forget that the colon in any ratio represents the word "to" so we can correlate an input to an output.
    So, .941 rotations in to 1 rotation out makes the most sense to me.
    Jul 2004
    Houston, TX USA
    30,857
    Or "over drive "
    Ever notice the vehicle transmissions with "over drive" express that ratio as always being less than one
    Mar 2017
    LATVIA
    535
    139
    266
    the work that needs to be done is usually represented by the "1", from there you calculate how much work you need to do at the input side to get the result of "1" at the output, in this case - 16/17 of the 1, or 0.941:1
    Jun 2012
    Michigan
    11,623
    3969
    4133
    How To Calculate Gear Ratio - HBReducer
    Re: Divide the driven gear teeth by the drive gear teeth.
  9. #8
    Dec 2015
    45
    9
    16
    Divided by, goes into, always gets twisted around in my dyslexic mind.
    Quote Originally Posted by johnoder View Post
    Or "over drive " Ever notice the vehicle transmissions with "over drive" express that ratio as always being less than one
    That’s what I was thinking.
    Thanks guys!
  10. #9
    Jan 2007
    wales.uk
    1,194
    131
    186
    [QUOTE=michiganbuck;3409841]How To Calculate Gear Ratio - HBReducer
    As correctly pointed out driven / driver (DRIVEN MAD BY THE DRIVER)I did a lot of that in college, make up little rhymes as we weren’t allowed to look up formulas in exams so you got good at remembering them, on the down side I remember just about every formula and can’t remember what day it is
    Mark
  11. #10
    Oct 2012
    325
    124
    148
    Is the tooth count metric or imperial?
  12. Likes Bobw, Lewie liked this post
  13. #11
    Dec 2015
    45
    9
    16
    Quote Originally Posted by bloomautomatic View Post
    It's Romulan!
  14. Likes James H Clark liked this post
  15. #12
    May 2017
    Minnesota
    1,220
    1529
    822
    It's Canadian.
  16. #13
    Mar 2005
    Kansas
    7,894
    486
    3757
    Quote Originally Posted by Gordon Heaton View Post
    I disagree, it is driven over driver. In your example, a rear end has a large ring gear (driven), and a small pinion (driver). So say you have 4.11's, 37 teeth on the ring divided by 9 teeth on the pinion.
    I'd call the OP's a .941:1, or for clarification, call it a .941:1 overdrive gear set.
  17. #14
    Nov 2009
    Massachusetts
    437
    143
    English isn't quite precise enough to depend on people all getting the same answer. I would always say which gear turns faster.
    Likewise with ratios in general. I always say something like ""the xx, computed as aa divided by bb".
  18. #15
    Feb 2007
    St. George, Utah
    1,047
    594
    693
    Quote Originally Posted by gbent View Post
    Aren't we saying the same thing? Like I said (post #2) in the OP's case, .941 revolutions for 1 rev in the driven gear. In my example, 4.11 revolutions for 1 in the driven gear. The only difference between what you said and what I said is that you referenced an overdrive set while I did not. The results are the same.
  19. #16
    Nov 2003
    5,406
    188
    1802
    The only proper way to do it is with Roman Numerals. So it's
    XXXII to XXXIV.
  20. Likes JohnEvans liked this post
  21. #17
    Feb 2012
    southern Or.
    642
    674
    473
    Just glanced at this and said to myself "well that's simple".
    After reading all the following posts now I am not so sure.
  22. #18
    Mar 2005
    Kansas
    7,894
    486
    3757
    In your original post you have driving/driven. I said its driven/driving, and used a ring and pinion to illustrate your rear axle ratio example.
    In any case, its easy to get words so similar confused.
  23. #19
    Feb 2007
    St. George, Utah
    1,047
    594
    693
    You are quite correct. I meant to infer that the driving number was listed first, not infer a mathematical operation. I should have written it so: driving:driven.
  24. #20
    Apr 2018
    4,159
    1878
    No, it's driver over driven. Rear end ratios are one of those cases where people have been doing it wrong so long that wrong becomes normal, but in general use it's always driver/driven.
  25. Likes 10 fingers liked this post
