2.5" facemill on straight shank arbor? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Nov 2014
    Florida
    6,382
    2552
    3158
    I don't see an issue with what you want to do. If you grind a decent flat (just large enough for a cup point to it can't move up or down) it should be fine.
  2. Likes Lock liked this post
  3. #22
    Oct 2019
    Montana
    104
    10
    18
    Called Techniks(still imports er32 holders for the routers) said they could custom make min 3pcs at roughly $200 ea with 6mo lead and they would deff be interested in buying several if a run was made; my rep(techniks) suggested Leitz tooling and Brinney tooling for quicker results, Brinney could make them but said it would be aprox $600ea and Leitz is looking into shrink fitting a straight shank arbor(guess they make shrink fit holders for the router crowd,) supposed to get a call back from them in AM.
    Really starting to think the best COA is to do a straight shank short term until I can make a short run of proper holders which involves moving an OD grinder home and reassembling.
  4. #23
    Oct 2009
    Oregon
    6,625
    7057
    3936
    This is an easy machining job with a decent lathe. You don't need to make the entire toolholder. Just start with one close and whittle away what you don't want.
    I have toolholders that were welded up and machined. Probably done in the 80's and still working fine.
    OD grinder is fine, but not required at all.
  5. Likes eKretz liked this post
  6. #24
    Jan 2007
    Flushing/Flint, Michigan
    11,121
    666
    8892
    You only have 5 hp.
    Could go down to 1/2 in a set screw endmill holder.
    Boring it open an option if you know what you are doing. The OD is likely not real true to the insert pockets.
    Bob
