Mike C.
- Nov 25, 2004
- Birmingham, AL
Had a 16 hole bolt circle to drill and tap on the radial drill this week. Apparently nobody on this planet makes a Morse Taper 4 tap driver for a 20x2.5 tap?
Perhaps you could use a 4MT tanged shank ER collet chuck. There is such a thing as ER tap collets with internal squares, but I guess you have to watch the square size to match your tap.
Metric taps are made to several different standards, so the shank diameter and square size for a given thread size can vary. In the USA, ANSI shanks are common, but ISO, DIN and JIS shanks will be different.
Standard Tap Dimensions (ANSI Shanks) - Tapmatic Corporation ANSI taps let metric taps fit common USA size collets.
Standard Tap Dimensions (DIN 374) - Tapmatic Corporation
Thread standards and tapping hole tolerances
Larry
Nope, a 20mm tap has a 15mm shank. It will not go in a 3/4" driver. I have most every tap driver over 1/2" and nothing fit the 20mm. A 19mm tap fits a 3/4 and a 22mm fits a 7/8".
What's available from Collis (not including specials):
Tool Holders, Mill Holders, Collets: Collis Toolholder Iowa
It seems odd that the M20 can't be had in 4MT.
I guess no one is reading Larry's post, or my #12,
I've learned quite a bit from this thread myself.
If you look at the table in post 3# from Larry, it's all right there, an ANSI 20MM tap has the same shank and flats as an ANSI 13/16 tap (NOT a 3/4), .652 shank, .489 across the flats, nominal.
ANSI metric taps are the most common type generally available in the US (as GarW said). all you need to do is order a 13/16 ANSI holder if your tap is .486-.489 across the flats ANSI, however going by your post 10, if its 15MM, I don't know what that is, so you probably need to get an ANSI tap as well, easy enough.
It's a bit of a mess as far as metric tap standards go with ANSI, ISO, DIN 374, DIN 358 whatever, and JIS. I didn't get as far into the weeds as comparing the latter 4, does anyone have a handy reference table for that?
Notice
