So I have a part that will be 7075 aluminum and has quite the deep pocket. The pocket is over 3” deep but it’s a through hole and the only way I can figure I can do it is half from each side. So from each side I will have to go 1.75” deep. The pocket has 2mm radi on the corners and is about 3/8 tall by 1” wide. I was thinking of drilling the corners out but now I’m thinking I will drill a hole to plunge a 1/4 tool in do as much as I can then come back with a 5/32 endmill and finish the walls and corners with small stepdowns all the way.
Is this how you would do it? Or would you try to predrill the corners with the right drill?
Give me your suggestions on how to do this cost effectively.
Now the caveats. I’m limited to 3 axis and 7000rpm. I would also like to keep cycle time reasonable and avoid breaking the endmills. I’ve found them both from Melin and Harvey and they are $40 a pop. Also need to hold better than .004 on this. This needs a time effective strategy as I need 150 parts.
Also I have normally just done chamfers or used a corner rounding endmill but I don’t have one needed for this part can a 3D contour with a ball nose produce a decent radius quickly?
Would you recommend Harvey tool or Melin? I can get the Melin shipped for the price of the Harvey before shipping $39 for a 5/32 stub flute extended reach 3flute 1.875 reach endmill.
