Just how much machining have you done, ...cos' that jobs little more than 1st year apprentice work.
It is 1mm thick. Not 2 mm thick.
Sound workable? FYI, I'm trying to get very tight tolerance on this.....
one single set up...drill,bore,turn OD, part.
.040" wall and you are going to bore and turn it? Can I watch please?
You don't need very tight tolerances, its a boring bar, if you stuck the 20mm bar in the 22mm hole and do the grub screws up it will work far better than you would thunk it wouldn't!
its kinda the whole beauty of single point turning, somethings just matter way less than they seam like they should!
Gotta remember man kind for well over 100+ years has been single point boring long before the notion of the luxury of a precision adapter sleeve. Kinda chicken and egg, what came first the adapter sleeve or the hole to mount it in?
Not a problem here. Why would you think so? I'd most likely start with 4130N tubing.
My thoughts exactly, ...though I freely admit 0.010'' wall thickness in PTFE (Teflon) is getting a bit tricky.
Advice from a slightly less new guy: less time on the internet and more time making chips.
I'd make it on the end of a bar and just part it off, but the procedure you've suggested would work just fine.
I can't think of any reason your sleeve would need to be hardened, all it does is fill a space. If you're not familiar with the KISS principle, Google it.
Notice
