3/8-16 ID x 1/2-13 OD stainless threaded insert 3/4" long plus or minus 1/16 or so
Does anybody sell one? I have been searching for 2 days and haven't found one. I think I need to go the full depth as the top of the cast aluminum comes to a small block about 1/2" thick the meatier part of the block is just below that.
The original hole is 1-1/8" deep and threaded as far as it could be.
I do not want to go with a bigger OD insert because I fear it would be too big.
I am thinking about trying to drill and tap a 1/2-13 stainless bolt.
Can an N bit be used for a 3/8-16 tap bit?
I do not have a 7.7mm and was trying to use the smallest bit that would still allow the tap to work.
Any advice would be greatly appreciated
