I need a thru hole in 6061, about 3.25" deep, to be .378 -0/+.003 after anodizing. My anodizer says I'll have about .0006 per side, half of that being buildup, so I was going to go for a .3795 hole before anodizing. My current plan is to spot drill, then drill 23/64 thru from one side with a good taper length drill, then ream with a .3795 reamer with plenty of cutting fluid. I can do the reaming in the machine (should I have a special holder for this?) or with a hand drill or drill press.
I did think about drilling from both ends and then reaming through, but my concern is that they won't be perfectly concentric and the reamer will follow a wandering path.
For the drill, a Guhring 535 series is readily available. It looks like a good drill and says it's good for non-ferrous and steel, just not stainless. It doesn't, however, give speeds and feeds for regular aluminum, just for cast aluminum. That seems pretty common and confusing. For example, the 5536 says on it's page that it's good for non-ferrous, but then the non-ferrous section is blank on the speeds and feeds document.
It looks like the best drill for aluminum might be the 501, but it's just for non-ferrous. I'm only doing two of these parts, so if I can buy a more versatile tool and use it again on another project, that would be great.
