SonofaMachinist
- Oct 24, 2019
Hello Everyone,
My first post, so be gentle.
I have 2" drill bit with a #3 MT and want to use it in both my 16" South Bend lathe that has a #2 MT tail stock and also in my Bridgeport with the R8 spindle.
The job I am doing only requires through drilling about 1 1/2" depth. Same part for both the lathe and mill. The difference being whether the part is pre-welded in an assembly or not. Probably do this a couple of times per month, in pairs.
Here are the options as I see them:
Buy adapters for both tapers. (expensive for what I'm doing)
Turn the drill taper down to #2 MT and buy an adapter for the mill. (Saves some $)
Turn the drill to 5/8" straight shank to use in drill chuck (lathe) and collet (mill). (Is 5/8" sufficient to hold the torque of a 2" drill?)
The adapters to make this happen add length that I don't really need. The drill is 8" long plus the MT. So, I'm tempted to shorten the drill itself. This was a freebie and I don't anticipate using it for anything else. But, I would hate for whoever winds up with my junk, after my demise, to need it longer.
Thoughts or opinions?
Thanx,
Bruce
Thanx,
Bruce
