Is 304 stainless bad to use on a hydraulic press? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21
    Aug 2012
    California, Central Coast
    5,092
    2373
    2101
    Quote Originally Posted by lalojamesliz View Post
    but what is wrong with the press?
    It is made of Chineseium
  2. Likes lalojamesliz liked this post
  3. #22
    Jun 2014
    New Jersey
    252
    270
    149
    you might want to drill the pin out and create some inserts for it.
    that's how my home made press is.
    I have inserts of 4140 or 4130 (can't remember) for general use.
    and then I have a bunch of different punches that I can stick in to push out narrower things, or set narrower things.
    drill it out and make a new end. BTW I put a set screw in to hold whatever I put in the end.
  4. #23
    Sep 2012
    California, Ventura county
    1,991
    866
    880
    First thing do this to it
    Then use real bolts
  5. #24
    Oct 2020
    22
    7
    Quote Originally Posted by 72bwhite View Post
    Then use real bolts
    So your saying to make one?
  6. #25
    Sep 2006
    SE PA, Philly
    5,589
    1117
    2059
    Uno.... that's hilarious!
    I do like the lexan idea. I can only think of a few more things that I'll need the press for before I sell it. Will 1/4 lexan be thick enough? Weave wire cloth sounds nice too since it will be easier to hang.
    A few commercial curtains use 1/4 lexan in a frame. Maybe bolted to a piece of square tube, top and bottom, and hung? Lexan was width of press and about 3 foot tall.
    The wire mess curtains extended from the height of the press to a couple feet from the floor.
    Thermite may write funny*, but he did experience real life combat. For him to be impressed with a projectile flying around, well, I take that scenario seriously.
    BTW, if you do weld a tip on the end of the press pin I'd face it first. I guess you gotta bevel, too, to get proper penetration.
    *One is reminded of James Joyce's comment on his work "Anyone wanting to understand my work will have to spend a lifetime". Or somesuch (anyone got the exact quote?)
  7. #26
    Feb 2007
    St. George, Utah
    1,260
    817
    851
    No, he's advising you to make a substantial ram guide. One that will keep the ram vertical and centered. Most of the chinese presses come with a single loose-fitting plate.
  8. #27
    Mar 2014
    220
    72
    I have heard more than a few times of the Harbor Freight 20 ton press being a scary thing to use if you attempt to get anywhere near 20 tons. The frame will flex and bend and the part will go flying. Sometimes directly at the operator. It works fine for for small jobs but don't push it to its limits. The Chinese seem to have a special grade of mild steel they make many things out of that is not much stronger than aluminum.
    I have a Chinese made 60 ton hydraulic log splitter I bought a year ago. It was the biggest one I could find. The 60 ton rating is a joke as I would be surprised if it even gets to 40 tons. But anyways the first time I ran it hard on very big pieces of eucalyptus, all the bolts marked as being good grade hardened steel, sheared off and almost took my leg with it. I replaced all the hardware with USA stuff and all is fine now. But as its made out of the same crap mild steel, I pay very close attention when running it.
  9. #28
    Sep 2012
    1,991
    866
    880
    Yup the way it came from china the ram waded up like a pice of tin foil
    And the work went shoot across the garage.
    Now it just creeks and groans.
    Also managed to put a bow in the lower support so replaced that with some real chanel
  10. #29
    Virginia
    18,885
    7561
    11641
    Quote Originally Posted by bosleyjr View Post
    Never got that far.
    "Work" my arse. "Masturbating with the printed word", y'mean.
    Joyce wasn't just hard to read. He weren't worth the effort!
    Ireland only blessed him for lack of the distraction of a potato famine in his time to temper their wicked sense of humour.
  11. #30
    Sep 2006
    SE PA, Philly
    5,589
    1117
    2059
    Never got that far.
    See? See?
    But I did catch the use of the "u" in humour. Writing in Irish, very clever.
    Seriously though, wasn't Joyce doing a bit of the same thing with the printed word? And don't deprecate your writings here - it is a body of work. Good heavens, Bill, can you imagine 3000 years hence, somebody finding the PM data repository backups, and for some reason could only decrypt and read the oeuvre of "thermite"? Man, that might send a less solidly grounded anthropologist into the loony bin.
  12. #31
    Oct 2005
    21,070
    Then use real bolts
    Bolts won't fix a bad design, implemented badly.
  13. #32
    Oct 2020
    22
    7
    Since I'm only going to use it for some control arm bushings, maybe the rear bearings on that same car and possibly a couple bearings on the transmission I'm thinking of I'll just do the lexan shield with some square tubing I have and replace the top bolts and then sell it.
    The top bolts are 5/8"x6" now. You guys think grade 8 bolts are good enough or look for something stronger?
    I'll get some 1.5" x 5/8"
  14. #33
    Oct 2020
    22
    7
    Quote Originally Posted by Gordon Heaton View Post
    Oh, okay. Thanks
  15. #34
    Sep 2012
    1,991
    866
    880
    Hence you fix a big design flaw first
  16. #35
    Aug 2012
    5,092
    2373
    2101
    Grade 5 should be fine. To do a nice job don't use the 1 1/2 bolts, they will have threads in the holes, get bolts that are straight shank in the holes so all or most of the threads are outside the holes. Different brands will probably have different shank lengths so shop around if you can. To make that look good you could cut off the excess threads, if they will be seen inside it.
  17. Likes lalojamesliz liked this post
  18. #36
    Oct 2020
    22
    7
    Quote Originally Posted by Rob F. View Post
    Grade 5 it is. Thank you Rob.
  19. #37
    Aug 2012
    5,092
    2373
    2101
    Something else to do when you swap the bolts is to get all the bolts in hand tight, then put some pressure on the jack to raise the head up in the bolt holes and then torque them.
