kb0thn
Stainless
- May 15, 2008
- Winona, MN, USA
So here is my story of the evening:
I have a piece of 0.1" thick 6062 aluminum sheet that I need to put four 4.5" holes in. I purchased a brand new Morse Cobalt Bi-Metal hole saw (http://www.mkmorse.com/mc1.html) for the job. Saw specifies 105 RPM for aluminum.
First attempt was with hand drill. Lots of catching and trying to break my arm. A few times with the drill running off on its own and wrapping the power cord around it. Okay, I learn ... decide to try cordless drill with clutch. Whenever the hole saw touches the aluminum the clutch engages. All this is a bit of a surprise, because I have put dozens of 3.5" holes in sheet metal with a cordless drill before. Usually a 10 second job and no fear of death involved.
After some more fiddling with hand drills I decide to put it on my CNC knee mill. But not mill it, just use this damn hole saw I bought. Clamp sheet to mill with strap clamps and a nice virgin piece of plywood for backing. Slowly feed. Hole saw grabs and pops the Rohma Supra keyless chuck off the arbor (JT33 taper). This is a big surprise, because that chuck has seen some serious use running things like 1" silver and demming bits through steel. So I cleaned out the taper and set the thing a little harder than I originally had. While fiddling around I notice that where the weld seam is on the hole saw there is a tooth that appears to have come from the factory sticking outside of what should be the OD. I carefully ground that down and figured that was the problem.
Take final attempt with newly reset drill chuck and dressed hole saw. Grabs again immediately, stalls the 2HP mill, pops the sheet metal free of the clamps, bends the arbor, and gives me a couple of nicks on my arms before I can hit the e-stop.
Throughout the different scenarios, I tried using Anchor Lube (thick water based cutting lube) and running dry.
What am I doing wrong?
-Jim
PS - only third time having to hit the e-stop since I started machining 7 years ago. First time was brand new machine, commissioning it. Home switch on z (knee) installed in the wrong spot from factory. During home cycle machine attempts to run ball screw through the floor and flip the machine over. Second time spindle faults, but machine doesn't shut down the axis drives. And now this. I guess I'm not doing too bad.
-Jim
