it might not be meaningless, if I understand the OP correctly and having seen quite a few sports cars, and either designed, modified or made replacement/new parts for them, the bar in this case doesn't act as a spring, because there are links at the ends that act as a spring, and it is by design, one of those links is "fixed" to the bar, the other one can be rotated, think of the "fixed" ones cross section being "I" shaped to resist bending and stay light, and the other link is adjustable, from completely "vertical" I to 45 degrees / to "horizontal" -, making the sway bar assembly act rigid or soft depending on the needs of the driver
so I suspect that the OP thinks the bar does act as a spring and wants to prevent it, to give greater control over the stiffness of the assembly by adjusting one of the links
