SShep71
Hot Rolled
- Sep 17, 2014
- San Diego, Ca
I need to make a press brake die set, top and bottom. It is a custom radius set that is 16" long, there is a 25mm radius that needs bent over the entire length. I have some 440 stainless sitting here that is perfectly sized, would that work or are there mechanical issues with trying to use material of the sort? I only need to press a few sheet metal parts, no production runs or crazy numbers. I don't have much experience with press brake dies, normally I would look for some 86/87xx series but I do not have anything sized correctly right now.
