440 stainless for press brake die?
Results 1 to 14 of 14
    Sep 2014
    353
    83
    58
    Default 440 stainless for press brake die?
    I need to make a press brake die set, top and bottom. It is a custom radius set that is 16" long, there is a 25mm radius that needs bent over the entire length. I have some 440 stainless sitting here that is perfectly sized, would that work or are there mechanical issues with trying to use material of the sort? I only need to press a few sheet metal parts, no production runs or crazy numbers. I don't have much experience with press brake dies, normally I would look for some 86/87xx series but I do not have anything sized correctly right now.
    Jan 2007
    Norfolk, UK
    21,369
    16734
    17433
    First off - what material are you bending?
  3. Likes digger doug, BT Fabrication liked this post
    Sep 2014
    353
    83
    58
    18-16 gauge CRS sheet that already has one draw/formed operation completed.
    Jul 2007
    Missoula Mt
    1,367
    60
    644
    Real bad idea, ss to soft...Phil
  6. Likes BT Fabrication liked this post
  7. #5
    Sep 2014
    353
    83
    58
    Phil can you elaborate a little. I have never heard of 440c stainless being too soft. I was worried about issues with cracking along the center line of the radius from grain alignment, cracking from hardening and ductile fractures, but never would I have expected to hear 440c stainless being to soft.
  8. #6
    Oct 2017
    1,311
    418
    446
    We formed and welded 1/4" A36 to bend 1/4" 5052 to a 70 degree overbend. It works without issue.
    If you are concerned about galling, use die film. I don't have personal experience with stainless dies, but 304 stainless bends against HRC 60 (I think?) dies with only surface marking. No galling or gouging.
  9. #7
    Oct 2017
    1,311
    418
    446
    This handles 12 tons per foot without issue (calculated).
    For the punch I wouldn't be concerned about material. Even aluminum is fine.
    You didn't mention what angle you are bending to. I'm assuming you want to air bend a 90. If so, are you sure you don't already have V dies that can work?
    If you need a deep overbend, that's the only time I would be concerned about the forces trying to split the die apart.
    If you want to bottom bend it's a whole different deal.
  10. Likes Limy Sami liked this post
  11. #8
    Jul 2007
    Missoula Mt
    1,367
    60
    644
    Its soft compared to steel and will gall quite bad, anytime you bent metal it will slide in the dies and gall, if this is a one time jig go for it but if it is a use every day dont...Phil
  12. Likes BT Fabrication liked this post
  13. #9
    Sep 2014
    353
    83
    58
    Quote Originally Posted by Phil in Montana View Post
    440C is softer than steel? 440C, the same material knife blades are made out of is softer than steel? Am I missing something? I know 303, 304, 316, are very malleable due to the near lack of carbon, but 440C has more carbon than 4140 (for just one example) a full percentage point in some cases.
  14. #10
    Oct 2017
    1,311
    418
    446
    A huge factor in galling is shoulder radius. If you make a large enough radius you can use material barely harder than what you are bending. If you have sharp corner radii even very hard steel will suffer.
    In your case I'd use what you have but make the shoulder radius as large as possible (which is pleasant for all dies anyway. It's only an issue if you have holes near the bend zone.)
  15. Likes SShep71 liked this post
  16. #11
    Oct 2009
    Louisville, KY, USA
    1,128
    221
    285
    You've said it's just a few parts. Make the dies out if any old scrap you've got around the place.
    I agree that 300 series stainless would be a bad idea, but the unknown 400 series stuff hanging around my shop is plenty hard enough.
  17. Likes Bobw, SShep71 liked this post
  18. #12
    Nov 2019
    CANADA
    Ontario
    601
    929
    142
    will it work, yes
    will it gall and marr, yes both the material and the die which will leave marks on everything after.
    one time use, sure, go for it. ive seen dies with plastic inserts for 1 or 2 parts that work until they deform too much
  19. #13
    Mar 2012
    Geilenkirchen, Germany
    2,862
    1608
    1499
    440c is plenty hard, but like others have said, it is likely to gall. Doing something twice is always way more expensive than doing it right once.........jus sayin
  20. Likes BT Fabrication liked this post
  21. #14
    Sep 2014
    353
    83
    58
    There seems to be a good amount of for and against. Roll the dice and see what happens I guess. Nothing ventured, nothing gained at this point.
