5 axis puzzle : how to ?
Results 1 to 18 of 18
    Apr 2018
    3,859
    1744
    Default 5 axis puzzle : how to ?
    In 1961, when this was made, how would you do this in quantities greater than one ?
    Entire page
    Revolving-Block Internal-Combustion Engines.
  2. Likes Larry Dickman liked this post
  3. #2
    Jan 2014
    Temecula, Ca
    3,075
    1344
    4000
    I would farm it out
    Apr 2018
    3,859
    1744
    Quote Originally Posted by Larry Dickman View Post
    I would farm it out
    THAT cracked me up
    May 2005
    Interior British Columbia
    2,405
    249
    755
    Well, I think the standard procedure, would be to have anyone you showed the picture to sign a non-disclosure agreement, then start talking up how much of a percentage of the profits the guy that actually made it was going to see instead of being paid time and materials....
    Oct 2005
    16,651
    I would farm it out
    To that Greek guy....what's-his-name...
  7. Likes Garwood liked this post
  8. #6
    Jul 2006
    Hillsboro, New Hampshire
    8,509
    2057
    5917
    As I see it, the toroidal cylinder segments can be made fairly simply, with just an offset boring bar with a projecting cutting element (or two, three, whatever, as long as they're relatively narrow and they're all in direct alignment), then a simple rotational motion of the "block" halves (which doubtless start as cored castings) transits the boring bar/cutting edges into the open section of the block.
    Around a 30* arc is needed, short enough that a ~1 to 2 bar-cutter diameter ratio should clear (or somewhere around this). Rotate the block half back to start for cutter removal.
    The two end segments are truncated cones, so easy to do on a regular lathe.
    The rest, as they say, is mere sweat and setup. Ah, for the old days when machinists didn't need the crutch of CNC...
  9. Likes Zahnrad Kopf, eKretz, bryan_machine liked this post
  10. #7
    Nov 2003
    5,212
    184
    1667
    "... how would you do this in quantities greater than one ?"
    I think you have struck on the reason why it is not under the hood of any car today.
    Seriously, if you were to make them in any number you would need a bunch of specific task machines and fixtures. The key here is that you need to sell enough of them to pay for that special/single purpose tooling. If you made only one of a new design, it could cost millions. But if you make millions of them, they only cost hundreds. You have to pay for the tooling: all in one or spread out.
  11. Likes bryan_machine liked this post
  12. #8
    May 2011
    New Jersey
    2,422
    213
    1309
    Looks like one of those rube Goldberg drawings...or where's waldo
  13. #9
    Apr 2018
    3,859
    1744
    Yes, I was thinking for a onesy, an indexing table mounted to a rotary table should do the job but for more than that, kind of a nightmare. The pistons are even worse, how to get a cam on them ?
    I guess this is a classic case of "engineering does drawings, let the farging shop figure out how to make it"
    Definitely an interesting engine design .... maybe use oe of these in my hybrid, instead of that ineficient gas microturbine
    Would this make a good student project or what ? I'd give an A to anyone who built one of these ...
  14. Likes eKretz liked this post
  15. #10
    Sep 2010
    Vancouver Canada
    957
    713
    353
    i wonder if the working version actually had the curved cylinder bores. You could imagine if there was a little radial freedom at the piston's connecting pin the cylinders could be straight. Thanks for linking to the museum of retro technology. I'm excited to go down that rabbit hole!
  16. #11
    Jan 2007
    Flushing/Flint, Michigan
    8,382
    438
    6897
    What part or section here is the difficult side in more than one off pre-cnc or nc?
    Straight curves around a C/L so no cams.....Pistons a bit more thinking but no so hard.
    Bob
  17. #12
    May 2017
    Massachusetts
    376
    404
    191
    Riffing on Larry's response...An inventory of snarky answers:
    - You didn't specify in 3D did you? So with tracing paper...?
    - You didn't specify tolerance did you? So with a die grinder...?
    - You didn't specify material did you? So with clay/ceramics...?
    Seriously though, interesting design.
  18. #13
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,958
    1365
    580
  19. Likes Milland liked this post
  20. #14
    Mar 2017
    203
    100
    I wonder what a motorcycle with a rotating block engine would be like except super dangerous? Might be hard to steer?
    Mechanical inversions of this type are interesting but are often impractical. I have worked on a few inverted clocks where the pallets were held stationary and the entire clock swings back and forth instead. They are interesting but rare, at least in part to their being a complete pain in the ass.
  21. #15
    Jul 2007
    Brookfield, WI
    622
    813
    545
    Although I happily yield to Larry Dickman's brilliant response, I would do that under an assumed name.
  22. #16
    Jan 2007
    8,382
    438
    6897
    I would farm it out
    Yes indeed.
    If not a big dog go sit on the porch and watch while we do the work.
    Bob
  23. #17
    Jun 2006
    Near Seattle
    4,826
    3221
    1334
    Well, historically, other complicated shapes have been made in volume using special machines, or somewhat more general machines driven by various templates.
    (See various videos of how wooden airplane props are made, etc.)
    For the curved cylinders, I would imagine developing a sort of "ball tool" (like a lollipop cutter on steroids) put in a special machine to move it.
    Getting pistons, cylinders, rings, etc. to match the tolerances of modern engines would end up being very expensive.
    It also, to my eye, has no apparent advantage.....
  24. #18
    Apr 2016
    94
    46
    41
    Makes my head hurt looking at that
