Hi fettersp:
At the risk of sounding like a complete dickhead, I have no idea what that scribble you've put up as a drawing is supposed to represent.
Do you have any other information you can give us?
How about photos of the setup you are planning on the actual mill?
Moving on to the ambition to position a hole on a manual mill on a compound angle to within a thou (+/- 0.0005"); how do you propose to interrogate it to see if it's where you hope it to be?
What are your datums from which you intend to measure?
How confident are you that your mill is "kicked over" to exactly the correct angle.
Will you locate off a tooling ball, or a scribed line or a touch with a cylindrical pin or ???
Do you have room to put in the hole close to it's desired location and then adjust the outsides of the part to bring it into position?
Do you have the means to mount a tooling ball, position it, verify it, and then pick it up and bore on that location without shifting the spindle axis relative to the ball when you run the table up and down to get the indicator and tooling ball out and the boring head into the spindle.
What kind of mill are we even talking about...do you hope to do this on a Bridgeport?
A Moore jig borer?
A cheapo asian import?
The more information you can give us, the more intelligent our response can be; so send us photos and let's see what we're up against.
Cheers
Marcus
