57/64th drill bit
Results 1 to 17 of 17
    Apr 2020
    Michigan
    68
    Default 57/64th drill bit
    Stopped in to a local second hand metal supplier. They have lots of reclaimed metal. They also have tools, motors etc. They had a bin of new Chicago Latrobe 57/64th drill bits. I don't have many larger bits and for 2 bucks couldn't pass it up. Problem is I don't have a chuck to hold it. Would you make an adapter to hold the bit that would fit my chucks, or try and turn the bit shank to a smaller size?
    Jul 2004
    Houston, TX USA
    32,129
    Bigger ones I turn to 3/4 dia.
  3. Likes Limy Sami, digger doug liked this post
    Oct 2009
    Olympia, Wa
    778
    336
    245
    The shank should turn down with carbide, it should be softer than the tip.
    Jul 2007
    Missoula Mt
    1,366
    60
    640
    Why did you stop at 1???...Phil
  6. Likes yardbird, Bobw liked this post
  7. #5
    Apr 2004
    Modesto, CA USA
    8,540
    1632
    1/2 is sd drill shank size. For a bit that is really too big for the chuck it is best to make the shank triangular not round.
    Bil lD
  8. Likes AlfaGTA liked this post
  9. #6
    Apr 2020
    Michigan
    68
    I’ll probably go grab a couple more
  10. #7
    Nov 2007
    marysville ohio
    10,655
    2980
    7365
    Quote Originally Posted by mwill135 View Post
    I hate turned down drills. I just use the proper size chuck. The only place I use SD drills is if for some reason I need to use a hand drill. For anything larger than 1" in my drill press or lathe I use taper shank drills.
  11. #8
    Oct 2005
    21,685
    Quote Originally Posted by Blazemaster View Post
    What, no whisker re-inforced ceramic inserts ?.....
    I've done it with HSS. (the morse taper part)
    You may have an "all HSS" bit, in that case, yes carbide.
  12. Likes richard newman liked this post
  13. #9
    Sep 2006
    SW Wisconsin
    738
    207
    269
    Quite often the flutes and tang are hard and the taper proper is soft. Hit it with a file and you will know. Found that out turning a 5MT to 4MT for a friend.
    Ed.
  14. #10
    Apr 2020
    Michigan
    68
    “Use the proper size chuck “ that’s assuming you have one.
  15. Likes mike44 liked this post
  16. #11
    Oct 2005
    21,685
    Quote Originally Posted by atex57 View Post
    Ed.
    Your educating me sir ?....
    Done many of them.
    They are friction/flash welded and you will find that weld quickly.
  17. #12
    Jan 2005
    Houston
    6,988
    1273
    3996
    Well, you don't say what the shank is now so it's hard to say...
  18. #13
    Sep 2006
    SW Wisconsin
    738
    207
    269
    Done many of them.
    If needs be.
    Most of the drills I have turned are as I described, the tang is hard then it gets softer as you get to the taper then gets harder as you get to the working area. Some are as you describe, hard line to cross, that is why I said to check them with a file. Some I have are that are so old that they have a soft tang and taper with the flutes silver brazed on, don't use them much.
    Ed.
  19. #14
    Sep 2005
    Connecticut
    4,704
    631
    673
    Quote Originally Posted by moonlight machine View Post
    I use S&D drills in steps for enlarging holes.
    If I had to actually drill a 1" hole on my lathe, it would spin the morse taper in the tailstock :-)
    Steve
  20. #15
    Virginia
    19,739
    7561
    11862
    I have a few around I've WELDED to get longer shanks than I had to-hand, but it isn't easy to get 'em centered.
    "Jacobs type" chucks (or Albrecht type) - largest here is 3/4" - simply don't HOLD well above 3/4" even if you had such an animal.
    You didn't tell us what spindle you expect to use it on, nor what, if any, other options you have for said spindle or spindles, plural, besides a "chuck"?
    My case, ER, Rubberflex, or TG, for lathes, mills, and the larger drillpress. So it's fine as it is.
    PITA to turn a HSS shank, (prolly M42?) down, if only 'coz they are a nuisance to center and still get a decent grip on.
    But you might have to drop clear to 5/8" for the more common Jacobs chuck. The 3/4" inch capacity ones are bulky and not that common. And NOW you will also need three flats - as Silver & Deming's use - lest you just slip it instead of driving it. Most of my larger drills have MT shanks, anyway, so..
  21. #16
    Apr 2004
    Modesto, CA USA
    8,540
    1632
    I think I special ordered that size. Is it the tap size for one inch acme?
    Bil lD.
  22. #17
    May 2005
    Interior British Columbia
    2,720
    312
    913
    For two bucks, I would have had a hand full of those.
    Doesn't really matter what they are the tap drill size for, they sure are a nice start to any bored hole that is supposed to be larger than that!
    Another one here, saying turn the shank down to what you can use, 3/4, or 1/2 inch.
    I would skip the flats to engage the chuck jaws.
