I use an interapid 0.0001” indicator model 312B-1. I have noticed that when centering something in the lathe jaws, it matters what direction the lathe spindle rotates. For example, if you rotate the lathe forward and adjust until you get “0” movement, and then rotate the lathe in reverse, I get about 0.0003 to 0.0004 movement in the indicator. (indicating that am not quite centered up)
At first, I thought that the pivot maybe had a little side to side movement and the direction that the stylus moved across the surface effected the side load on the stylus, thus causing the differing readings. However, I recently made a roller with ID and OD cut with out removing from the chuck. It was highly polished and for grins, I put the indicator on the inside bore and then the outside diameter both on the near (operator) and far (back) sides of the part which has the effect of the part sliding by the stylus in both directions depending on where the indicator is located. As long as the chuck was rotated either by hand or at 70 rpm (slowest I can go), it read perfect in run out. No perceptible needle reading what so ever. But when I rotated the chuck in reverse, I got about 0.00035” run out. It did not matter where the indicator touching the part (front or back). In this case, since the part had not been out of the chuck and was highly polished, there were no surface finish related “noise” to muddy the water so to speak.. it was easy to see and the indicator reading were clear…
So now I think it must be something with the spindle bearings… Could there be a slight amount of slack in the bearings (say maybe a couple of tenths) and as you rotate the spindle, the bearing biases itself toward one side? i.e, trying to climb up the high side so to speak and moving the spindle axis a little. Then when you rotate the other direction, you get the same effect and it moves the spindle axis in the opposite direction?
That’s about the only thing I can come up with. It was clearly related to the spindle direction, and not to the mounting or friction of the stylus on the part.
Maybe I need to tighten the spindle just a little? By the way, this is a Grizzly G4003 lathe about 20 years old. I am the only owner and have taken very good care of it. I know the Chinese lathes are not the best in quality, But I have had no reason to complain on this one and have thoroughly enjoyed in over the last 2 decades..
Look forward to your thoughts…
