A1-6 face plate
Results 1 to 16 of 16
Thread: A1-6 face plate
    Dec 2010
    Albany, GA
    51
    65
    Default A1-6 face plate
    Can someone make me a A-6 face plate
    12" OD
    1.500" thick
    with 29/64th slots
    for 4, 6 & 8 mounts
    if interested I can supply more details
    tks
    jay
    Aug 2012
    California, Central Coast
    5,584
    2468
    2360
    If you can get a D1-6 faceplate, remove the pins and drill holes for your mounting bolts you will be good to go. The A and D difference is bolts or pins.
  3. Likes Jay Moore liked this post
    Dec 2010
    Albany, GA
    51
    65
    Tks,
    on second thought it needs to be 2" thick
    with solid center so I can machine bushings for different pilot sizes
    also, needs to be wear resistant steel
    for cutting open torque converters
    tks again,
    Jan 2005
    Victoria, Texas, USA
    5,108
    3984
    1532
    This should make you a perfect face plate.
    Semi Finished 12-1/2” Diameter A-6 Adapter Plate | eBay
    Why does it have to be 2" thick? I believe these are around 1-1/2 thick. I bought one from these guys many years ago just for that. I think the one I bought was 10.5" OD and had a thickness of around 1"-1-1/4". Plenty of thickness for a face plate.
    I had face plates of over 18" diameter and were only about 1/2" thick with a 1-1/4" flange on the OD.
    To me 2" thick is a over kill.
  6. Likes Jay Moore liked this post
  7. #5
    Dec 2010
    Albany, GA
    51
    65
    It needs to be thick because of the pilot centering bushings
    I am duplicating the flywheel to engine relationship
    Ford, GM, Nissan ect. from converter pads to start of bushings can be 1 1/2"
    and then the bushing needs 1 to 1 3/4" depth
    also the faceplate you suggest is not beefy enough
    we also remove balance weights with a burp gun while converter is held to the faceplate
  8. #6
    Jan 2005
    Houston
    7,776
    1686
    4768
    The term 'wear resistant steel' is meaningless.
  9. Likes Jay Moore liked this post
  10. #7
    Dec 2010
    Albany, GA
    51
    65
    thank you,
    well, a steel that is machinable and more durable than cold roll
    tks
  11. #8
    Jun 2016
    New York
    2,267
    1883
    1131
    Quote Originally Posted by Jay Moore View Post
    thank you,
    tks
    if you need a wear resistant bore, make one. expecting the backplate to do everything is a mistake. we mount our workholding TO a backplate so the thing mounts on the spindle.
    why do you need the "backplate" to be you work holding? buy a backplate, mount a piece of whatever steel you like to it, and make what you need. if that is beyond your skills, explain clearly what you are trying to do to a competent machinist, and pay them for their time appropriately.
    what you have posted so far is completely inadequate to even make sense of, let alone bid on.
  12. Likes 4GSR, Jay Moore, BT Fabrication, CalG liked this post
  13. #9
    Dec 2010
    Albany, GA
    51
    65
    I plan to use the face plate to cut open torque converters
  14. #10
    Dec 2010
    Albany, GA
    51
    65
  15. #11
    Nov 2017
    South Carolina
    325
    79
    95
    Can you post a sketch or a photo of what you're looking for, to better understand your needs ?
    Bob
  16. Likes Jay Moore liked this post
  17. #12
    Dec 2010
    Albany, GA
    51
    65
    Here is a drawing
  18. #13
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,414
    1205
    910
    7/16" slots all the way through 2" thick harder-than-mild-steel will be slow to cut. Your faceplate will weigh around 75 lb
  19. Likes Jay Moore liked this post
  20. #14
    Dec 2010
    Albany, GA
    51
    65
    yes all the way through
    but regular steel will be ok
  21. #15
    Nov 2017
    South Carolina
    325
    79
    95
    Check out your PM's.
    Bob
  22. #16
    Nov 2017
    South Carolina
    325
    79
    95
    I had some good discussions with Jay to figure out exactly what he needed.
    We put together a CAD drawing and exchanged that a couple of times to be sure everything was clear.
    We ended up with an overall thickness of 1.0" for the face plate, 12.75" dia.
    The overall thickness of the boss needed to be 2.75" to allow for a bore, with a step at the bottom, and the A6 taper.
    Ordered a 3" thick A36 blank, 13" diameter, that weighed 120 lbs. The job ended up about 47 lbs.
    The critical dimension were left so that Jay could mount the adapter on his lathe, and skim them to ensure concentricity.
    We made a very simple gauge to measure the taper, see sketch, out of a piece of 1/8" strip. We tipped the mill head over 7.5 degrees, and milled a step at each end. Then put the head back to zero and milled the "flats", so that a caliper resting on the flats could measure the 4.188" inch dia at the mouth of the taper. Then filed the edges a little to minimize the contact area - worked out quite well.
    We did the taper a little large, 2 or 3 thou, so Jay could skim the face to get a precise fit up.
    All worked out well and Jay seems be happy.
    Bob
