I came across a nice Rohm 12-inch independent 4-jaw chuck with integral A1-8 mounting taper and holes.
My Monarch 16 CY has a D1-6 spindle.
I had the idea to turn an adapter as pictured below to use a spare D1-6 mounting plate to mount the 4-jaw chuck.
The adapter would fit the ID of the straight bore going through the D1-6 mounting plate and will fit the A1-8 taper on the 4-jaw chuck. The chuck will be attached to the backing plate with bolts with the adapter sandwiched between the chuck and backing plate.
Seems like a straight forward solution but since I couldn't find any such animal commercially available I wonder if I'm missing something. Any reason this wouldn't work? If it makes any difference, the chuck and lathe don't see any heavy duty work anymore.
Full resolution pictures here:
4-Jaw - Google Drive
