HurleyByrd
- Jan 21, 2011
- WV United States
I've just spent something like 4 hours researching various materials to use as bushings in a lumber sawmill I am building. I have two chrome plated 3 1/2" diameter x 74" guide posts that will be installed vertically. The posts will guide the sawmill's 4 bushing head up and down the posts. The idea in my design can be seen in the photo. The Cook Sawmill shows two vertical posts which the head rides upon. They are the two light colored, vertical posts behind the bandsaw. The pictured posts are far smaller than the ones I just bought since Cook's mill needs to be portable and manufacturing costs maintained.
Keep in mind, my mill be will be far more potent. It will run a 30HP electric motor, be permanently installed and the head, band-wheels, pulleys, framework, motor, etc.... will weigh in around 1500 pounds. But all that weight is kind of irrelevant to the load bearing needs of the plastic. The only real pressures applied on the bushings will be "slight" when the mill runs through the log. There is no need for substantial bearing load on the bushings. They and the posts are strictly there to maintain the head's vertical/horizontal positioning. AND.... I'd like to protect the guide posts since they will be a very HARD item to replace.
My question............. What plastic should I use? And what fits should I aim for with a 3.5" post? I was originally going to make the bushings in bronze (which I have in stock) since I was going to use steel rounds and live with greasing the posts. But after the arrival of the real guide posts, which I bought sight unseen for a song and dance..... I found them to be beautifully chrome plated, ground and ready for the job at hand. I started looking at Acetal, etc... in order to protect the posts. BUT am completely ignorant of plastics in machine design. The more I read.... the more confused I have become.
I will be making the bushing holders and bushings in my shop. So, they can be designed as needed to hold any size bushing and there will obviously be 4 bushings. SOOOoo... the bushings can be slim, thick, long, short, etc.... I have no idea yet. But in my mind, it will be easiest to make round holders and bushings on the lathe. Being a sawmill...... I want to keep the use of oils and greases to a minimum.
What reasonably priced material should I use for these bushings? Keep in mind, I want the bushings to wear of course, not the posts and I have no issues with replacements in the future. AND.... for the next year +-..... the mill will be in the weather until I can produce the lumber needed to build a building. It will then never see rain again.
Thanks for the help,
Pete
Pete
